Sponsored by: Real Truck
Rough Country LED Install: HELP Needed
Old Feb 21, 2016 | 08:08 PM
acf6's Avatar
acf6
I would just use one of the lowest rated upfitter switches, and use the output to trigger both relays for the light bars. Why waste one of the 25a switches if you already paid for the wiring harnesses with relays when you bought the light bars
Old Feb 22, 2016 | 12:27 PM
falloutboy89's Avatar
falloutboy89
Thanks for all the feedback
Thanks for all the feedback. I'm going to keep the relays from Rough Country and just connect via the 10 amp upfitter.
I really appreciate the help. Should be able to find time to do this sometime this week. Can't wait to see how strong they are!
Old Mar 14, 2016 | 11:55 PM
alredmtnhunter's Avatar
alredmtnhunter
which switch wire do i use
so i am doing basically the same thing. I am installing 2 30" rough country bars on my 2012 f250. I am planning to use both of the factory supplied wiring harness and just use the upfitter for the switching part. The supplied switch (which i am removing) has a white, blue and black wire. I assume one of those wires is used to light the switch. Has anybody figured out which wire needs go to the hot on the upfitter switch and which is ground? What do i do with the three wires?
And since i am just using the upfitter to power the switch, and keeping the relays supplied with the two harness', could i just wire both switch wires to the same upfitter?
its almost midnight here and i think im in over my head on this one..
thanks
Old Mar 15, 2016 | 07:23 AM
The rock99's Avatar
The rock99
I just took mine apart, white supplies power to the switch, black is ground, blue is the actual relay control, pushing the button joins the white and blue and trips the relay. So the upfitterswitch needs to be connected to blue.
I would recommend disconnecting the switch at the plug, then slide the wire loom on the relay side of the switch cable back and clip it off, leaving 2-3 inches of wire on the plug side, so that you can reinstall it later if you decide to ever use the switch, or sell the lights. Tape off the white and black, and connect the blue to whichever pass through wire you decide to use, if you have both lights, and want to use one upfitterswitch connect both blues together and then connect to the pass through. I would use the upfitterswitch with the least amperage, saving the bigger ones for later.
Old Mar 15, 2016 | 03:48 PM
falloutboy89
I did what the Rock mentioned. I ended up using upfitter #3 (since it was the smallest) for both lights.
Old Jun 3, 2016 | 09:55 AM
tspeier's Avatar
tspeier
I installed Rough Country's 30 inch dual setup less than 2 months ago and one of the lights already has condensation behind the lens. The condensation is along the entire length of the light bar. It looks like a cheap light bar now. If I hadn't already cut my grill in order to install these lights I wouldn't do it. I am very disappointed.
Old Jun 3, 2016 | 10:08 AM
-dave-'s Avatar
-dave-
Sound like a broken seal. They do claim a 3 year warranty so that should be your first call.
While I too worried about the light quality, so far so good. Knock on wood.
Old Jun 3, 2016 | 10:12 AM
DieselCamper's Avatar
DieselCamper
Same here. It's taken a beating and keeps on trucking.
Old Jun 3, 2016 | 10:25 AM
tspeier's Avatar
tspeier
I contacted them already and they told me it is normal to get condensation behind the lens and that I should just run them for awhile to clear it up. I did run them for and hour with no change. So I replied back via email and told them I'd like a replacement. They have not responded since last week.
Here is their initial response to me:
"It is common for the lights to get condensation in them. Will need to run them for a little bit and it will clear up. The lights are vented. "
Old Jun 3, 2016 | 10:36 AM
tspeier's Avatar
tspeier
I called them rather emailing this time and they are send me a replacement. Woo Hoo!
Old Jun 3, 2016 | 11:39 AM
The John's Avatar
The John
I haven't purchased a light bar yet.... but I will be in the next couple of months. The very first thing I do after an out of the box inspection of the light, will be to seal around the lens with some clear silicone (Lexel Adhesive Caulk) . From what I have heard (from several people) is that the lenses will allow just a little bit of moisture in and doing this will keep the condensation out of the housing.
Old Jun 8, 2016 | 06:34 PM
AK_SuperDuty's Avatar
AK_SuperDuty
I'm looking at this light kit for a new 2017 Super Duty I'll be taking delivery on later this year. I'm considering wiring two upfitter switches in parallel to both relays. One of the upfitter switches would have a contact off the high beam relay tied in series upstream of where it connects to the relay coils. I figure I can leave that switch on and the light bars will swap on and off with the high beams, or I can flip the other upfitter switch on and it will keep them on constantly. What do you think Rock?
Old Jun 8, 2016 | 06:44 PM
  #28
-dave-'s Avatar
-dave-
I went with just one which is way bright enough
Old Jun 8, 2016 | 08:33 PM
  #29
ufvj217's Avatar
ufvj217
looks awesome!!!
Old Jun 8, 2016 | 10:52 PM
  #30
KCCOsteve's Avatar
KCCOsteve
I'm not rock, but you should be able to do it with two relays, because the relays would isolate the power from each other and prevent back feed to the high beams. That said, I would ask myself if I would actually use that feature much...
Edit- actually I would use 3 relays... So you aren't adding any draw to the high beam circuit.
