Didn't know that even existed. A month or two ago, I got the Morimoto LED fog lights. They are much, much whiter than the stock incandescent fog lights. Almost blue I would say. When I first installed them, I aimed them to "match" the beam (or apparent beam) from the originals, and they just didn't seem very bright or useful at all.
Then I started looking at them closely, the originals have a lot of spill-over light that goes above and below of the main beam. However, the Morimotos have an extremely tight beam. There is almost zero spill over outside of the main beam. This required that I aim the LED lights a few degrees higher than the originals. Now that I've done that, I like them very much, and I think they light significantly better than the originals, and are better mainly because they have so little "scatter".
