New engine
Old Feb 19, 2016 | 08:13 AM
Larietpsd's Avatar
Larietpsd
New engine
Did anyone else remember seeing an artical about ford developing a new superduty engine for the 18 model year? If so what ya think they doing? Big block maybe 7.4 out of retirement
Old Feb 19, 2016 | 08:21 AM
fordmantpw's Avatar
fordmantpw
5.8L is what I've heard.
Old Feb 19, 2016 | 09:57 AM
MadWolf's Avatar
MadWolf
Don't know if it was true, but I heard something about a Supercharged 5.8 option in that new bronco for 18'. maybe that's the same engine. I can't imagine them adding an NA 5.8 to the SD lineup.
Old Feb 19, 2016 | 10:20 AM
fordmantpw's Avatar
fordmantpw
I doubt you will see a S/C in a Super Duty (or anywhere else in Ford anymore for that matter). I could see a 5.8L with a single turbo (or even 2) slapped on it though...
Old Feb 19, 2016 | 10:38 AM
phillips91's Avatar
phillips91
I wouldn't mind seeing something like an ecoboost 5.4, 5.8 or 6.2 or a n/a 7+ liter big block.
Old Feb 19, 2016 | 04:27 PM
LSchicago2's Avatar
LSchicago2
I could 100% see a Coyote based 5.8 in a Super Duty.
Old Feb 19, 2016 | 04:44 PM
MadWolf's Avatar
MadWolf
Brings me to another question.. What is the main logic behind using turbos, instead of a supercharger? ...I guess the turbos are lighter, cheaper, saves more fuel?
Old Feb 19, 2016 | 05:04 PM
phillips91's Avatar
phillips91
Basic version, superchargers are belt driven and provide boost based on rpm. Turbos are exhaust gas driven and give you the option of no boost under light acceleration(fuel savings under light acceleration and more power under heavy acceleration).
Old Feb 19, 2016 | 05:50 PM
Larietpsd's Avatar
Larietpsd
I'm thinking fords gonna go 5.8 direct injected something along those lines tried and true
Old Feb 19, 2016 | 08:00 PM
fordman19762003's Avatar
fordman19762003
On one of the other forums guys were talking about the 5.0 turbo charged engine that Ford has developed so that would be my guess.
Old Feb 20, 2016 | 01:39 PM
Louisville Joe's Avatar
Louisville Joe
I have heard the new engine is a 5.8L too. Doesn't make much sense because it sounds like the 6.2L will continue as well.
Old Feb 20, 2016 | 02:14 PM
LSchicago2's Avatar
LSchicago2
Superchargers are better off idle though, and don't usually lag like turbo's. Superchagers typically have power all through the range. Turbo's are a bit more efficient, but are usually best in the mid range RPM's on any production vehicle. Turbo's also create more heat in general.
Old Feb 21, 2016 | 06:22 PM
fordmantpw's Avatar
fordmantpw
The main reason for turbos is efficiency. Turbos use waste energy from the exhaust, whereas superchargers are belt-driven, meaning they zap power from the engine. I've heard 10% as a good figure of energy needed to run a super charger.
I'm thinking the 6.2L will remain low-tech whereas the 5.8L will be DI and DOHC, maybe even turbo charged.
dstegjas
Sep 17, 2017 10:41 AM
Patrick R.
Jul 5, 2015 07:18 PM
jfritz_drfritz
6.7L Power Stroke Diesel
43
Oct 2, 2013 06:38 AM
SuperLB51
Jul 11, 2005 04:11 PM
