overdrive driveshaft
Old Nov 1, 2004 | 06:24 PM
Ford Blue's Avatar
Ford Blue
I am putting in the original 3 speed overdrive transmission into my 66 SWB F-100. My driveshaft was changed by the previous owner. If anyone has a SWB F-100 with a 3 speed overdrive can you please measure your 2 piece driveshaft? Thank you.
Old Nov 3, 2004 | 11:55 PM
jav409's Avatar
jav409
You need just the frount mesurement or both ? is this a 352 ? Raining hard here so proly wont be able to get under it till sunday.
Old Nov 4, 2004 | 09:59 AM
Ford Blue's Avatar
Ford Blue
I need the measurements from where it bolts to the transmission to where it bolts up to the rear end. Thanks. It just stop raining here today.
Old Nov 8, 2004 | 04:45 PM
jav409's Avatar
jav409
Ok I measured from the end of the transmition housing to the end of the visabull splines in the primary driveshaft it is 29 1/2 inches, then from the frount end of the secondary driveshaft ( the part that slides over the primary driveshaft splines ) to the end of the yoak in the secondary driveshaft . it is 45 1/4 inches , now you would need to minus the distance of the end of rear yoak out of the trany to get your primary length,( their are i think two differant ones ) also I do not know how much spline is inside the secondary driveshaft. I hope this helps some.
rumblinbass
Nov 23, 2008 04:23 PM
cars2cool
Jul 14, 2008 07:26 PM
kooper909
Feb 14, 2005 10:50 PM
revrick
Jan 24, 2005 08:40 AM
82F100SWB
Oct 13, 2002 07:27 PM
