Pay or play?
Old Feb 17, 2016 | 01:49 PM
Ford'05HG's Avatar
Ford'05HG
Pay or play?
In a few weeks I will be bringing my new to me Ranger back to the great state of Texas. The truck however, has a squeak when running, which I think has been concluded as the idler pulley for the timing belt. Well, I'm nowhere near the truck still and in order for it to get here it will need to be driven half a day to reach me, at which point I could do all the work it needs done.
My question is: Should I take the risk and have it driven here before the belt change (I did look at it while I was out there and it's already cracking pretty good), or should I go ahead and have someone get the belt done at a shop? It's less the belt that concerns me I think, and more the pulley, even though it's just started squeaking in the last 1000 mile.
Any one?
Old Feb 17, 2016 | 02:14 PM
khadma's Avatar
khadma
Carpenter Local 745
How many miles on the odometer?
What engine?
Are you talking about timing belt or serpentine belt?
Old Feb 17, 2016 | 04:10 PM
Rockledge's Avatar
Rockledge
If the engine is the 3.0L then you need to confirm that the squeak you are hearing is not actually a failing camshaft synchronizer (CMP) assembly.
(Good description of the issue HERE).
Old Feb 17, 2016 | 08:18 PM
Ford'05HG's Avatar
Ford'05HG
There's 110,000 miles on it.
It's a 2.5L
Checked the serp already and it's fine.
Pretty sure it's the timing tensioner and the belt I believe is also 110,000miles. And that bugs me a little.
Old Feb 18, 2016 | 06:36 AM
Kruse's Avatar
Kruse
With the engine obviously running, grab a 2 or 3 foot section of old (or new) heater hose and use it like a stethoscope. Be careful that the hose doesn't get sucked into a belt or pulley.
Old Feb 18, 2016 | 01:37 PM
Ford'05HG's Avatar
Ford'05HG
The truck is too far from me to do anything to by myself. That is why I'm here. I'm almost positive it's the tensioner pulley under the timing cover, if it's not that, I couldn't care less about what's happening to the engine beyond that. It won't be in there for long anyways.
The point of this post I guess, is to ask you all what you would do.
Would you be afraid to put over a thousand miles, or run this engine another 12 + hours, practically non-stop, with the timing components on their way out?
Old Feb 18, 2016 | 06:58 PM
Rockledge's Avatar
Rockledge
If I'm not mistaken, the Ford Ranger 4-bangers are non-interference engines, so at least you won't wreck the engine if the tensioner and/or timing belt fails.
Old Feb 18, 2016 | 07:54 PM
Ford'05HG's Avatar
Ford'05HG
That's what I've heard too, but it would be significantly more expensive of a trip back...
Old Feb 18, 2016 | 09:21 PM
merkswitch's Avatar
merkswitch
Among the first things I did when I bought my truck with 120k on it was replaced the timing belt, and it was definitely overdue. I don't know how much longer it was going to last, and I didn't want to find out the hard way.
I'd say, if in doubt, do it right and give yourself peace of mind.
Old Feb 19, 2016 | 06:13 AM
03 Maz B23's Avatar
03 Maz B23
If a tow vehicle is available rent a dolly and go that way. At that mileage if timing belt is questionable then I would be additionally concerned about cooling system, tranny, wheel bearings etc on that long drive. Wouldn't want to have to pay for any of those repairs en route with an unknown on skill level of one doing the repairs. Just my two cents.
Old Feb 19, 2016 | 07:32 AM
MikeB 88's Avatar
MikeB 88
I bought my 2000 Ranger with the 2.5L with 138,000 miles on it. First thing I did was change the timing belt. As far as I could tell, that was the first time.
katula
13
Aug 7, 2021 11:53 AM
Kijutsu
Apr 19, 2009 09:06 PM
meck1
May 11, 2008 06:23 AM
Rob Widdup
Oct 22, 2005 08:36 PM
Dunner
30
Feb 3, 2004 03:43 PM
