Its time for a turbo, my mechanic friend said to start planning getting one. Here is the question, I have a 2003 motor in a 2004 Excursion studded and SCT tuner 4" exhaust with air intake. It is a daily driver, just hauling the kids around town and family trips. I don't like the whistle from the turbo, it got old after a bit! Looking to replace with stock or should i go with a Power Max , and with it have that whistle? I don't want to break the bank, keep it under $1300. What other options do I have?
stock turbo from eBay $800, no core. To use a 2005-2007 turbo (no whistle) would require a different turbo pedestal to mount it, not a big deal to install it. It would quite down the turbo, but also kill some performance.
PowerMax does whistle and will require some tuning to take full advantage, the stock STC tunes are not programmed for a PowerMax, you'd need custom tunes.... but it could improve performance significantly... as in MPG increase and power increase.
.....It would quite down the turbo, but also kill some performance.
PowerMax does whistle and will require some tuning to take full advantage, the stock SCT tunes are not programmed for a PowerMax, you'd need custom tunes.... but it could improve performance significantly... as in MPG increase and power increase.
You could install a muffler to quiet the exhaust.
This^^^^^
I recently rebuilt my turbo with the exhaust side of a Powermax ( late 2004-2007) and was appalled at how much better the performance was even with my stock, but billet compressor wheel. My truck pulls harder, has little to no smoke, and now gets better mileage.
Maybe by running Gearhead's SRL+ I'm still not getting the full benefit, but between AMZ2Al12 and then the Atlas 40 (both FICM tunes, one stock one Aftermarket), I have no problem spooling it and getting it to take off when I mash it.
Since you have an '03, you're more than half way there on the programming. Some Gearhead tunes should fix you up...
But the 1,000,000 question is: Why does your friend think you need a turbo?
These turbos are VERY rebuildable unless the CHRA is trashed on one side or the other. I know, I've rebuilt my fair share of them, mine included....
You took a 2003 6.0 turbo, removed the exhaust side and mated that to your 2005 intake side? Was the exhaust side on that 2003 turbo stock or actually a PowerMax unit to begin with?
So your saying that you could have bought just the exhaust side in the PowerMax and built it using a new exhaust side unit, but choose the used one because of price?
Here's the complete back story:
A buddy had a Powermax back in 2013, he was running some hot tunes and didn't have a 4 inch exhaust so Egts ate the turbine on the Powermax. To that end, I sourced a 2004 turbine, took the compressor side of his Powermax and put it on the late 2004 turbo. This left me with a damaged turbine/exhaust side of a late 2004-2007 Powermax. It sat in my garage for 3 years until my turbo decided it needed to be rebuild and I was able to source a complete 2003 turbine, unison ring, vanes, and exhaust housing for a good price. I simply used the vanes, unison ring, Powermax exhaust housing, and turbine to attach to my existing CHRA and good compressor. So while I'm still running a stock 2005 compressor housing with the Riffraff Diesel billet wheel, I now have the exhaust/turbine side of a Powermax/2003 turbo minus the different mounting of a 2003 turbo.
Originally Posted by Rellick
I second that '?', i thought the shafts were different on 03 vs 05...
The shafts are very much the same, what's different is the turbine size, height of the vanes, and how the turbine side mounts (pedestal)
I have absolutely zero personal experience with anything but the stock turbo on the 6.0 (and that's limited). But I have seen this mentioned a few times, especially for those not wanting the whistle and still getting the quick spool at the low end......it looks pretty sharp. They sell DIY kits on there website for around $725...
Crap....I'm not supposed to be looking at turbos - i can get myself into trouble again.....
KC Turbos - Ford 6.0L Powerstroke Stage 1.5
