Timing gears
Old Feb 17, 2016 | 06:16 AM
roadrash63's Avatar
roadrash63
Timing gears
Hi,
I have a 1985 f250 with the 300.
Dirt cheap ignition hei.
1979 yfa.
Anyway I'm looking for a steel/ metal timing set.
auto parts store around here only list fiber gear...
Did earlier sets use metal ?
Are the factory gears retarded ?
Cam set for use with stock exhaust ?
Ty !
Old Feb 17, 2016 | 12:56 PM
fordman75's Avatar
fordman75
The best set up to use is the Cloyes. Cloyes Timing Gear Sets 8-1014 - Free Shipping on Orders Over $99 at Summit Racing
Old Feb 17, 2016 | 04:07 PM
roadrash63's Avatar
roadrash63
Thanks fordman 75 !
Old Feb 17, 2016 | 08:21 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Or check RockAuto, they have some OEM replacement metal sets that aren't as pricey. Comp makes a set too.
Old Feb 17, 2016 | 08:24 PM
roadrash63's Avatar
roadrash63
Thanks Baron !
The other set was a little high...
Cam suggestions ?
Where earlier cams better ? (Stock)
Old Feb 17, 2016 | 08:38 PM
fordman75's Avatar
fordman75
The problem with OEM replacements is they don't correct the cam timing. Especially if you are doing a cam swap. You want the cam installed straight up. That's what's nice about the Cloyes it's adjustable. If it's too expensive then check Comp cams. They sell a set that will be slightly cheaper.
79super460
Sep 1, 2012 09:29 PM
hav24wheel
Mar 22, 2010 09:08 AM
classicranger
Nov 25, 2007 08:04 AM
bigbrown84truck
Oct 18, 2005 12:45 AM
lawnbiz
Feb 13, 2004 03:47 PM
