just looking to go with there 2.25" kit front and rear...more for ride quality than lift...do u need to buy new leaf springs with this kit? I see it has it listed for obs or superduty 99-up leafs? I plan on add 5100's and the steel braided brake lines also....do u need any other parts? track bar, track bar mount? new leaf springs front and rear?
on a side note? can u get a 5100 shock to replace the oem stabilizer shock?
just trying to make my parts list up for what I need....thanks
not really...the only thing I learned was that I need new leaf springs....couldn't find any info on track bars/mounts or about the 5100 for a oem replacement steering stabilizer shock
Like I said. you need to do a search. beat to death
Beat to death but lousy search engine. I have been searching on here for hours and still have not found the thread that say what year SD x code spring to use. I thought the site is to help people .
i got my u codes at the dealer from an 03 or 04 f350, google obs rsk, youll read for days.
You obviously have not searched if you Think you want X codes
WOW Again. no help. Thanks. I have searched but I found the answers on other site. the shop that sells the RFK said the best spring was x code for the 350 4x4. If you know better than help.
I find it helps to put the search in "quotations".
Thanks. I will try that. I did a search on RSK and got 3 threads. That is very little info. but now i get many pages. Perhaps the search was not working when i used it?
