Any Advice?
Old Feb 15, 2016 | 09:51 PM
NVFord81's Avatar
NVFord81
Any Advice?
Hey guys I got a 1974 Ford and we just put in a new 351m in it. Well whenever we try to start the truck or crank the engine it makes a screeching noise kinda like when you scratch a chalkboard. We thought we put the flywheel on backwards and we just took the engine out and noticed it was on correctly. We might also think it's the starter? Anyways any thoughts on what could cause this?
Old Feb 15, 2016 | 09:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
There is a difference in a standard or automatic transmission starter, did you use the correct one?
Take the starter and get it bench tested at the part store.
Old Feb 15, 2016 | 11:35 PM
NVFord81's Avatar
NVFord81
Well we never changed the starter when we swapped engines and it never did that in the old one. Once we put the new engine in it started doing that screeching sound. I don't think the starter could of gone bad that quickly, i'm just trying to find out what could cause this. Anyways I might just end up buying a new starter and trying it out.
Old Feb 16, 2016 | 05:07 AM
gatorfor88's Avatar
gatorfor88
When you say "new" 351m what does that mean? New reman, rebuilt or what?
Old Feb 16, 2016 | 10:24 PM
NVFord81's Avatar
NVFord81
@Gastorfor88 By new I mean a crate engine that we bought.
Anyways I was looking around a bit and does there happen to be a type of spacer between engine block and flywheel?
Old Feb 17, 2016 | 01:01 PM
Canus's Avatar
Canus
Yes there should e a plate between the engine block and the flywheel/flexplate. Use the one from the engine you removed.
Old Feb 18, 2016 | 06:52 PM
NVFord81's Avatar
NVFord81
Hmm no wonder.
Old Feb 18, 2016 | 09:16 PM
NVFord81's Avatar
NVFord81
Ok, well I was looking around again and some people are saying to get a bellhousing separator plate and others are telling me to get a flywheel shim. Not sure which one would get rid of the sound being cause by the starter. Can it be that the starter isn't aligned properly to flywheel? Would I need a shim?
Old Feb 19, 2016 | 06:56 AM
gatorfor88's Avatar
gatorfor88
Best thing to do is put the seperator plate back in. You would have to pull the tranny to "shim" (meaning afro engineer) the flwheel anyhow, might as well do it right. And if you "shim" (meaning afro engineer) the starter, you probably gonna eat the flywheel up and have to pull the tranny anyhow. Might as well do it right 1 time.
Old Feb 19, 2016 | 09:18 AM
Filthy Beast's Avatar
Filthy Beast
This is the separator you need. Goes between the bell and engine. Note the starter orofice on the left side
Old Feb 21, 2016 | 04:33 PM
NVFord81's Avatar
NVFord81
Oh ok, i'll just buy the separator plate instead. Thanks for all the help guys.
Red buck
Dec 28, 2017 12:36 PM
nothercrash
16
Jul 1, 2015 10:45 PM
RumRunner78
Mar 30, 2014 06:42 AM
ohiostater
Oct 16, 2010 09:09 PM
lref1
1997 - 2003 F150
Mar 7, 2007 09:28 PM
