04 ford 350 diesel
04 ford 350 diesel
Hi I am new and have an 04 f350 single axle 6.0 diesel my issue is I ran it all day Saturday morning shut it off for a couple hours temps were cold outside wind chill around negative 10 farenheight started fine drove about 8 miles truck was at normal operating temperature the whole time shut it off went inside to get a coffee came out would turn over fine but no start added diesel 911 to upper filter and into tank was told it was gelled I've had heat on the lower filter for about 3 hours still no start what could be my issue now ?
You've checked lower filter to confirm gelled filter? I've not had it happen but my understanding is once it starts gelling, it's almost impossible to fix with additives. I've not had to deal with this issue, so I can't help with that. Maybe someone with more experience will chime in on that. Do you have any guages to post data? FCIM main pwr, FCIM sync, ICP,fuel pressure, ipr.
I have no way to get full live data at the moment I know it's not gelled now anyways both filters have been replaced but still no start I will try the bowl in the daylight as I'm not working in a shop and it is also snowing was cold changing the filters lol and I need to recharge the batteries
Agreed. If you absolute HAVE to, follow the directions:
Mix the 911 correctly 50/50% with fresh diesel and (if you don't carry spares) soak your filters with the 50/50 mix. Don't assume the fuel in the tank is gelled and just dump it into the tank; clear both filters, then check for fuel flow, THEN if the tank or lines have a problem start adding it to the tank until it clears. The wax crystals build up in the filters before the entire tank is gelled up requiring the full dose of additive, and the 911 stuff is hard on the fuel system if it gets overconcentrated.
F-WhiteThunder
02-20-2012 05:13 AM
