6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Loud Engine? Noise
Old 02-15-2016, 10:35 AM
dochall's Avatar
dochall
dochall is offline
Loud Engine? Noise
I have a 2010 F250 with 6.4L diesel and tow a 36' 5th wheel. When going up a fairly steep grade going out of town about 3/4 mile up the hill the engine occasionally starts making a very loud high pitched noise, ( sounds like a jet engine or a boat motor cavitating) The tac does not change and the truck does not loose power, once I get to the top the noise subsides and the truck works normally. This also happens sometimes when the truck is cold. Resolves in a minute or two when it warms up.
Has anyone else experienced this? Do you know what it is? Is it a problem? My mechanic thinks it might be the electronic fan kicking into high gear, or the turbo.
The truck seems to work normally otherwise. Has lots of power to pull the 5th wheel.
Old 02-15-2016, 04:21 PM
dannyadames44's Avatar
dannyadames44
dannyadames44 is offline
Check your Coolant Level …My 2010 6.4 did the same thing!!
Old 02-15-2016, 04:23 PM
dannyadames44
Old 02-15-2016, 05:28 PM
CrazySob's Avatar
CrazySob
CrazySob is offline
Check for exhaust leaks... It is pretty common for the exhaust mani bolts to break.
Also check the up pipes for soot streaks.
Old 02-15-2016, 07:12 PM
eberlestock's Avatar
eberlestock
eberlestock is offline
I am thinkin fan kickin in?
Old 02-15-2016, 07:34 PM
CrazySob's Avatar
CrazySob
CrazySob is offline
That could very well be it as well. If its high pitch though I would expect an exhaust leak.
If its a howling it could just be the fan. They move A LOT of air and make quite a racket.
Old 02-16-2016, 10:06 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
Received 1,002 Likes on 770 Posts
what is the status of the boost pressure...does it increase during the wine?
hpcbmw
03-13-2015 07:41 AM
Liquid10Rider
11-01-2010 06:49 AM
MikeyG123
1997-2006 Expedition & Navigator
05-10-2010 11:18 AM
Bill Joanitis
04-27-2008 09:17 PM
FORDSDOWNER
04-25-2008 12:49 AM
Quick Reply: Loud Engine? Noise
