Keep alive memory
Old Feb 14, 2016 | 09:21 PM
Seanosu's Avatar
Seanosu
Keep alive memory
What is the "Keep Alive Memory" I see it in the pull down menu on AE when doing a buzz test. There is an option to clear it, what happens if I clear it ?
Old Feb 14, 2016 | 09:32 PM
madpogue's Avatar
madpogue
It's basically the memory that the PCM retains when you turn the key off. That's why the PCM has two power inputs, one that's always hot and one that's only hot with the key. If you clear it, it'll forget any stored codes, and it might throw a KAM error (something like P0603). If you have an automatic, I THINK I recall reading that the PCM does not "learn" your driving patterns and adjust its shifting accordingly, so there's nothing like that to be lost.
Old Feb 14, 2016 | 10:37 PM
Seanosu's Avatar
Seanosu
Thanks, I wanted to make sure I wouldn't wipe the PCM.
capt caper
6.7L Power Stroke Diesel
Mar 6, 2019 05:30 AM
Mattheweston
Jun 11, 2018 08:29 AM
williameub
Jul 1, 2015 11:05 PM
Walleye Hunter
Oct 6, 2014 07:03 PM
JoePeeper
Oct 29, 2013 01:42 PM
