Trany Question..... help
Old Aug 10, 2003 | 12:21 PM
madmax99's Avatar
madmax99
Does anyone know which line is which coming out from E4OD trany. I am under the impression the forward is the pressure out line and the rear line is the return line from the cooler is this correct?
also has anyone put an in-line temp sensor on theirs does it matter how far away from the trany the sensor is as long as it is on the pressure out line it should still be relatively accurate shouldn’t it
any help would be appreciated
Old Aug 10, 2003 | 12:30 PM
firedad's Avatar
firedad
the line to the rear is the return I believe.
