help with alt mod
Old Feb 10, 2016 | 08:52 PM
xaviar's Avatar
xaviar
help with alt mod
OK. I've done all the wire upgrades for the alternator but 1. Having
a little trouble with the positive to battery mod. I see that there is some kind of extension mount to allow the positive cable to be up higher away from the back of the alternator stud (see pic) and away from CAC. Can anyone direct me to this part that is need to move the location of the stud mount on back of alt to the top positive?
Thank you
Old Feb 10, 2016 | 10:24 PM
jswartz84's Avatar
jswartz84
You will have to get the extension that is clocked right for the alternator. Separate the housing on the alternator and install the extension from the inside of the housing.
Old Feb 11, 2016 | 04:28 AM
xaviar's Avatar
xaviar
I was hoping I didn't have to do that. Well, I'll take my old one apart and check it out.
Thx.
Old Feb 12, 2016 | 01:03 AM
Yahiko's Avatar
Yahiko
I have one that is just a bolt up from the outside.
Might be worth checking at some of the smaller auto parts stores.
You could also look and see if you have a rebuilder that is local and ask there.
Sean <BR>
6.0L Tech Folder
Old Feb 12, 2016 | 01:34 PM
xaviar's Avatar
xaviar
Sean <BR>
6.0L Tech Folder
Thx Sean. I'll check that out.
Old Feb 12, 2016 | 11:13 PM
xaviar's Avatar
xaviar
Well, I found this 3G-6G ford alternator post extension by Romeo Electrical. They are also posted on ebay.
Go down the middle of the page and you'll see the part# 1452038
http://store.alternatorparts.com/f1-452-038.aspx
So, this would allow us to safely mount the positive cable to passenger battery from alt. Looks like they're made here in the US also.
I'm going to order one and give an update later.
Old Feb 13, 2016 | 03:27 AM
Yahiko's Avatar
Yahiko
That's the thing I have on the extra alt.
Just mine is green and has a crack.
Sean <BR>
6.0L Tech Folder
Old Feb 13, 2016 | 10:40 PM
jswartz84's Avatar
jswartz84
I have one of those in my shop. I tried the same thing but decided I didn't want to split my alternator to install it.
Old Feb 13, 2016 | 11:06 PM
xaviar's Avatar
xaviar
You shouldn't have to split the alternator to install this extension. I thought it was a bolt on deal?
Old Feb 14, 2016 | 12:46 AM
jswartz84's Avatar
jswartz84
Maybe it'll work. I believe my problem was with the insulator ring on my alternator. I either had to cut it off or remove it, which meant splitting it apart.
Old Feb 14, 2016 | 03:55 AM
Yahiko's Avatar
Yahiko
If I have time to dig in that box I'll pull it out with the stock 119 unit
and we can have a look at some photos.
Sean <BR>
6.0L Tech Folder
Old Feb 14, 2016 | 01:41 PM
xaviar's Avatar
xaviar
Sean <BR>
6.0L Tech Folder
Ok, thx Sean. We appreciate it.
Old Feb 14, 2016 | 04:32 PM
Yahiko's Avatar
Yahiko
I should quit posting when I am really tired and my eyes are fuzzy.
Where did I get 119 instead of 110?
Sean <BR>
6.0L Tech Folder
Old Feb 14, 2016 | 05:06 PM
xaviar's Avatar
xaviar
Sean <BR>
6.0L Tech Folder
Wasn't sure about that either. I just chocked it up as a miss print. ....LOL
Old Feb 14, 2016 | 05:32 PM
Yahiko's Avatar
Yahiko
The Miss was not in the room at the time so it was a Mr print.
She happened to be out chasing invisible mice.
Sean <BR>
6.0L Tech Folder
Donzi Dude
Dec 3, 2016 11:08 PM
jblksmith1
Feb 1, 2016 07:21 AM
nmclella
Oct 26, 2015 02:57 AM
tbear853
Jan 8, 2013 10:08 PM
montanafordman
1997 - 2003 F150
May 6, 2008 06:17 PM
