Driving lights
Old Feb 10, 2016 | 07:27 PM
phillyken's Avatar
phillyken
Driving lights
Has anyone installed driving lights on the front bumper of a 97 Ranger?
Old Feb 11, 2016 | 05:09 PM
Hank85713's Avatar
Hank85713
I put some on a 94 which is basically the same bumper. wired them to the parking lights and then ran the ground to a switch in the cab. I used a relay to do this so I dont have an problem with a hot wire maybe rubbing and then shorting.
Old Feb 13, 2016 | 07:39 AM
phillyken's Avatar
phillyken
Wire to cab
How did you run the wire to cab? Thought about removing the fuse panel inside the truck and looking for an opening, If possible, I would also use a spare on the fuse panel for the hot wire.
Old Feb 13, 2016 | 09:52 AM
Hank85713's Avatar
Hank85713
The relay is mounted on the rad support with + from the headlight parking light. The - is run to a switch I installed by the headlight switch and the ground is completed at the Emerg brake handle. Short power wires long ground wire. Its just a toggle switch nothing fancy.
abvoitik
Mar 21, 2020 10:32 AM
Zaxbig89f250
Electrical Systems/Wiring
Apr 17, 2012 06:38 PM
JPdiesel
Sep 15, 2011 11:06 PM
tomtoc
Sep 9, 2007 08:58 AM
zman764
1997 - 2003 F150
Nov 26, 2006 10:35 PM
