Engine Identification 1973 C600
Old Feb 10, 2016 | 12:26 PM
fastx19's Avatar
fastx19
Hi Guys. I am having a bit of a problem figuring out the exact model of the motor in my C600 (1973)
It has five bolts for the valve cover and the intake manifold extends under the valve cover. So I was thinking it is a 360.
However, from what I understand the 360 is suppose to be stamped on the block on the passenger side near the front of the engine. I took quite a bit of time and there is no stamping of any type in this location. Unfortunately the tags for this motor are all missing.
Now, the carb is a 4 barrel Holley, which was on the 390 according to the manual I have.
Does anyone have any thoughts on how to ID the block?
The reason I ask is I need a new set of points (yes, I should convert) but I don't know what the heck it is. The condenser, cap and rotor for a 360 fit, but the points don't even come close.
Thanks for your patience on helping me with this.
Eric.
Old Feb 10, 2016 | 01:20 PM
gatorfor88's Avatar
gatorfor88
Well since a 1973 c600 is a dodge I dont have a clue what engine you got.
Old Feb 10, 2016 | 01:23 PM
fastx19's Avatar
fastx19
It's not a Dodge. Ford COE 600 series truck.
It is a 1973 COE Ford C600 ex moving van.
Thanks.
Old Feb 10, 2016 | 01:24 PM
gatorfor88's Avatar
gatorfor88
hmmmmmmmmmmmmmmmmmm
Old Feb 10, 2016 | 01:43 PM
gatorfor88's Avatar
gatorfor88
330 359 361 389 391 were all engines used in "medium" duty Ford trucks. You might reasearch these and find out which 1 you have.
Old Feb 14, 2016 | 09:32 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
The tune up parts are identical between all of the HD motors, and they are the same as the pickup stuff. Standard Motor Products points part number FD8081 Condensor FD77
I'll bet the points you have are miss boxed
If your engine has a 4BBL carb it should be 361 or 391, they were the only FT engines offered with 4bbls. It could still be a 330, on the outside they are identical and the manifold and carb will bolt right on.
Sam
dilmachender
13
Apr 20, 2014 03:32 PM
divinusmonstrum
24
Oct 25, 2012 08:58 AM
Glxy66
401, 477, & 534 SD Engines
Mar 9, 2012 11:41 PM
Customcab
23
Dec 2, 2011 08:45 PM
BigMac
Apr 19, 2000 07:04 AM
