Battery Cable Part#'s
Old Feb 10, 2016 | 11:27 AM
NewXer's Avatar
NewXer
Looks like the stock right side negative battery cable WC-95599-A has been discontinued.
It appears that an unofficial substitute is WC-9329-A. Can anyone validate or do I call a dealer?
Old Feb 10, 2016 | 01:33 PM
jpr38057's Avatar
jpr38057
The part # you are asking about is for the RH of a super duty. Dealer wouldn't be able to confirm yes or no. I would think it would work. If I knew where you were I might be able to find somewhere close that had it so you could look at it before purchasing.
Old Feb 10, 2016 | 05:39 PM
NewXer's Avatar
NewXer
I'll see what the dealer(s) because there are several around me have in stock before I buy, thanks for the clarity.
Old Feb 10, 2016 | 05:41 PM
NewXer's Avatar
NewXer
Dealer reply:
Thank you for contacting North Central Ford. Unfortunately, the battery cable you are looking for has been discontinued by Ford and is no longer available. The last Motorcraft number you found is the same one that I show. Some of the aftermarket dealers may be able to cross that number to get their equivalent.
I'll run with jpr38057's advice and see how the 250 cable looks first. Tried the aftermarkets... wasn't happy with what I saw. I'll make my own first.
Old Mar 29, 2016 | 05:53 PM
NewXer's Avatar
NewXer
Final...
I got the factory cables except for the pass side ground which went end of life, so I bought the F-250 cable for that year. It fit just fine.
Perhaps, I won't be fighting corrosion every 3 months on the new cables. Here are the old ones.
Old Mar 29, 2016 | 05:56 PM
NewXer's Avatar
NewXer
2000 7.3 battery cable part just incase someone else needs them:
Motorcraft WC8982A Battery to Ground Cable - Driver side
Motorcraft WC9329A Battery to Ground Cable - Passenger side (from F-250)
Motorcraft WC9329D Battery Switch Cable - Positive Cable
Old Apr 1, 2016 | 10:51 AM
R&T Babich's Avatar
R&T Babich
I replaced ours with marine larger gauge tinned wire and connectors with SS bolts.
Old Apr 1, 2016 | 10:55 AM
NewXer's Avatar
NewXer
My original intention was something to this effect, but I just ran out of daylight. Those look pretty good.
Old Apr 1, 2016 | 02:25 PM
Country_Mouse's Avatar
Country_Mouse
Don't happen to have (or tell me where to find) part #'s for a 2001 6.8 do you?
Old Apr 1, 2016 | 02:29 PM
jpr38057's Avatar
jpr38057
YC3Z 14300-GA Positive Retail $142.20
F81Z 14301-BA Negative Retail $72.54
Both are available from Ford.
Old Apr 1, 2016 | 02:31 PM
Country_Mouse
Awesome, thanks!
Didnt think they'd be so much $....
Old Apr 1, 2016 | 02:33 PM
Country_Mouse
Do I need a # for a ground one too?
Old Apr 1, 2016 | 02:35 PM
Tedster9's Avatar
Tedster9
One thing a lot of guys do, their local welding supply company can make up a set of 1/0 or 2/0 battery cables a lot cheaper than dealer supplied cables.
jpr38057's Avatar
jpr38057
14301 is the ground (negative).
Old Apr 1, 2016 | 02:41 PM
holeshotwalt's Avatar
holeshotwalt
Making your own with welding cable and marine or military style clamps, etc would probably be around $35 to $50 bucks for both...
