AXLE RATIO?
Old Sep 2, 2012 | 05:29 PM
bigfoot17's Avatar
bigfoot17
AXLE RATIO?
I have a 2003 E-150 with a 3.55 rear end,4.6 V-8 and 154000 miles. I was looking to upgrade to a 2011 or newer. I only see that they have a 4.10 rear end. Can I get a 3.55?
Old Sep 2, 2012 | 05:44 PM
95e150CW's Avatar
95e150CW
The E150 became an E250 with a door sticker downgrade and softer springs in 08. The shortest ratio you can get is a 3.73.
Old Sep 2, 2012 | 09:56 PM
Mark T-TB's Avatar
Mark T-TB
Maybe check the size (dia/circumference) of the different tires, too.
The tires used seem to get "bigger" all the time, makes for "taller" effective gearing.
My Expy has the 4.10 rear, but with the 265/70-17 tires, it only turns 2000 rpm at 77 mph.
Old Sep 2, 2012 | 10:17 PM
bigfoot17's Avatar
bigfoot17
Good point. Currently I run stock 15" rims with Bridgestone Insignia's that are 28.9" in diameter. I get between 16-18 mpg. The 2011 that I was looking at has 16" rims with tires that are 29.4". Don't know if that makes a big difference,but I don't want to loose mpg's.
Old Sep 3, 2012 | 09:26 AM
Mark T-TB's Avatar
Mark T-TB
That isn't much difference between the tire sizes. Any way to check the trans gear ratios?
With all of the focus on fuel mileage over the last few years, it seems unlikely that Ford would change things to make it worse... unless the new Van is considered "heavier duty"
How do the EPA mileage figures compare? ... of course the way those numbers are figured has also changed - around 2008(??) I think.
Good luck.
Old Sep 4, 2012 | 06:52 PM
bigfoot17's Avatar
bigfoot17
Good luck.
The EPA rating for the 2011, I was looking at was 13city/16highway
My 2003's sticker says 14 city / 18 highway which is very close to accurate.
Old Sep 4, 2012 | 08:42 PM
Club Wagon's Avatar
Club Wagon
Check your speedometer against GPS & your odometer against 100 miles of interstate mile markers. You might find more error than the difference between tire sizes.
Transmission drive ratios changed w/the demise of 3:55 rear.
Old Sep 4, 2012 | 09:11 PM
bigfoot17's Avatar
bigfoot17
If I can get my diff. to quiet down.(see my other post). I will stick with my 2003 another couple years.
jaskoskip
Jan 3, 2016 05:17 AM
Mr Boogie
Aug 16, 2013 04:45 AM
abah
2004 - 2008 F150
Mar 4, 2006 05:06 AM
jimmac
General Automotive Discussion
Jun 25, 2005 02:36 PM
wmcnally
Feb 20, 2003 07:32 PM
