1972 f100 4x4 very slow in 1st?
They don't call it the Granny Gear for nothing.
But what I want to know is how fast did you take it up to in 1st? If you drive it again do the following test just to make sure. Get moving in 1st and then let off the gas, and then back on the gas, and back off 6 or 8 times. If you look like one of those low riding wheel hoppers, you should be good to go.
It probably has the NP435 4 speed transmission where reverse was down and to the right. If so, 1st gear sounds normal to me.
I have to disagree with you on that one. Viagra or the generic equivalent is what he needs to throw in there. The clutch and gas pedal should become stiffer. If it lasts more than 4 hours consult your mechanic.
Your buying a 70's 4x4 truck not a 2wd truck or muscle car. 1st gear granny gear as most people call it. Never really gets used as you found out not very practical. I would use 2nd gear for pulling out most of the time when driving my truck. 1st gear is great for moving things around the yard or pulling stumps done that many times.
Do you know for sure if you were in 2wd or 4x4? Is there 4 shift points on the 4x4 t case lever? Just making sure you actually have a high and low speed 4x4 t case. You most likely have 4.10 or 4.54 gears in your diffs did you check them gears yet? You should be able to go more then 40MPH but your engine should be screaming around 65-70mph.
