clutch smells?
Old Feb 7, 2016 | 10:23 PM
dkerlee's Avatar
dkerlee
clutch smells?
I noticed an intermittant brake smell after getting off the freeway in my '89 Ford F250. Took a peek underneath, and it seems like the e-brake could use some TLC. Any thoughts on fixing this one, how I should do it, or replace it?
thanks!
Old Feb 7, 2016 | 10:36 PM
Lead Head's Avatar
Lead Head
Nothing is broken there. The bottom cable is rusted, so park brake on whatever wheel the bottom cable goes to is stuck on. You can try spraying some kind of lubricant down the cable, and wiggling it a bunch will usually get it freed up again, but its best to replace the cable.
General rule of thumb:
Always use the e-brake, or never use the e-brake.
Old Feb 8, 2016 | 11:51 AM
Bird-Dog 250's Avatar
Bird-Dog 250
Are you sure it's the E brake? A clutch smells the same. Do you use the clutch to hold the truck on hills? Is this the first time you smell this?
johnfowler25
Oct 31, 2016 09:44 PM
hotrodlincoln69
Sep 23, 2012 06:50 AM
48 Steel
May 3, 2008 11:09 PM
mindset
1983 - 2012 Ranger & B-Series
Aug 25, 2003 12:45 AM
