Steering stabilizer question
Old Feb 3, 2016 | 03:32 PM
BigBlueX's Avatar
BigBlueX
Originally Posted by pirate4x4_camo
If you were using a washer before then you have already accounted for its thickness in relation to where the nut engages the bolts treads. Did ATS recommend new nuts or just use the ones that the threads have already been torqued to yield ?
Any how, just because it is a common practice doesn't make it correct. But at least you know what to check first if you get, death wobble, wander or some other handeling quirk.
No they did not recommend new nuts. They said just go slow when removing the nuts but that I should not have any issues. Worse case scenario I'll inspect the threads on the nuts and bolts after removing and if they don't look right I can order new bolts and nuts.
My other option would be to add a couple more washers. The bolts look long enough.
Old Feb 3, 2016 | 03:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
For some piece of mind ...the bolt will stretch further and lose clamping force before it reaches ultimate yield. Rarely can they be driven long enough to actually break the bolt, they just come loose.
speedcostsmoney
Dec 23, 2013 04:55 AM
Phillyc1
Feb 23, 2013 12:03 AM
cowboyty
Mar 24, 2007 07:09 AM
Schmavic
Mar 13, 2004 07:30 PM
