starting trouble
Old Aug 9, 2003 | 08:48 PM
Trucky18's Avatar
Trucky18
starting trouble
My 95' Bronco has had a problem starting ever since i got it last year. Sometimes, more when its warm out it will not start when i turn the key, everything works like normal, fuel pump relay and everything, but not starting, but if you smack the dash, steering colum or fuse panel a couple of times it will start with no trouble, the other weird thing is that sometimes the speedo wont work either, but again you just have to smack the dash. I replaced the ingnition switch, but it made no differance. I am at a total loss. any one have any ideas?
Old Aug 9, 2003 | 10:41 PM
Franklin2's Avatar
Franklin2
starting trouble
When you say "won't start", do you mean it won't crank the engine, or the engine is turning but it won't fire?
Old Aug 10, 2003 | 12:12 AM
Trucky18's Avatar
Trucky18
starting trouble
nothing, no responce from the starter. as if the starter relay isnt getting the signal, if ther even is one under the dash
Old Aug 10, 2003 | 03:23 PM
thelonerangerxlt's Avatar
thelonerangerxlt
starting trouble
Trucky, do you have a main wiring harness connector at the firewall, under the master cylinder (with a screw in the center)? You could try unplugging the connector and spraying the contacts with WD-40, re-plugging, and tightening up the screw.
Old Aug 11, 2003 | 11:55 AM
blu's Avatar
blu
starting trouble
If its not starting and hitting the dashboard helps. Check the ignition switch at the base of the column. When you turn the key to start position theres a mechanical switch spring loaded inside the ignition switch that completes the circuit. Could be you need to clean the contact or adjust the position of the switch.
Old Aug 11, 2003 | 04:05 PM
Trucky18's Avatar
Trucky18
starting trouble
i replaced the ignigtion swith, with no change in behavior
Old Aug 11, 2003 | 04:10 PM
GR8Diesel's Avatar
GR8Diesel
starting trouble
When you get this no start condition and prior to smacking the dash do any of the accesories work? Radio, lights, etc.
Trying to determine if it is a power source issue up or downstream of the ignition switch...
Old Aug 11, 2003 | 10:13 PM
Trucky18's Avatar
Trucky18
starting trouble
ya, every thing works like normal, radio, lights evey thing, jut no starting
Old Aug 11, 2003 | 10:35 PM
GR8Diesel's Avatar
GR8Diesel
starting trouble
Have you checked the neutral safety switch and/or clutch safety switch? Both switches could be affected by hitting the dash...
Just a thought...
Old Aug 12, 2003 | 07:52 PM
Trucky18's Avatar
Trucky18
starting trouble
i ckecked the neutral safty switch, i looked fine, and i dont know where the clutch switch is. my trany is a E4OD, so is there a clutch saftey switch?
Old Aug 14, 2003 | 07:22 AM
GR8Diesel's Avatar
GR8Diesel
starting trouble
Sorry about the delay in answering - I'm having some internet difficulties. No, if you have an automatic then there is not clutch switch as there is not clutch. I suspect that you must have a bad connection where the cables pass through the firewall. Next time it happens, instead of pounding on the dash - try tapping areas of the firewall with a board.
Other than that I'm plum out of ideas.
Good luck!
Old Aug 14, 2003 | 04:20 PM
Trucky18's Avatar
Trucky18
starting trouble
ha ha, ya thanks, it has stumped me for months. I will try looking around that area. Im also going to look at the fuse panel, i think there are some issuses there. Would it be difficult to replace the whole thing?? I think some of the connections are a little loose, and they expand in the summer heat and cause these problems. again thanks
Old Aug 26, 2003 | 12:34 PM
pro3qtr's Avatar
pro3qtr
starting trouble
I have the same problem, still stumped!!
Spins over all day.
