Sponsored by: Real Truck
Front Brake Rotor Recommendations
Old Feb 2, 2016 | 08:47 AM
DirtRacer96m's Avatar
DirtRacer96m
I have a 2003 F350 SD FWD Dually With 4.10 Axle Ratio. I'm looking for some front rotors and pads and I'm looking for recommendations. I tow a 44' Goose neck racing trailer on a regular basis so I dont want autozone crap rotors that are going to warp in a few thousand miles. I was on rockauto.com, they have Wagner, Bendix, Motocraft, Powerstop, etc etc. I thought maybe those Powerstop drilled and slotted looked interesting, but I dont know much about them. Anyone have any thoughts or something they have used and are happy with? Thanks
Old Feb 2, 2016 | 09:22 AM
airm4n's Avatar
airm4n
I've heard good things about powerstop rotors but I ended up going with motocraft brand. 100,000k+ on a set so i'll stick with oem.
Old Feb 2, 2016 | 09:45 AM
nojoke327's Avatar
nojoke327
Ive got 105k on stock rotors with no warp so I will be going stock when I replace them
Old Feb 2, 2016 | 11:22 AM
CollinsCD's Avatar
CollinsCD
I went with stock Motorcraft after reading lots of great reviews. I don't really tow much so I can't tell you how they do over time and tows.
Old Feb 2, 2016 | 11:55 AM
andym's Avatar
andym
I went with EBC yellow stuff pads and Napa premium stock rotors. I tow a lot (probably not as heavy as you) and they perform great. Much better than whatever was on it before. Better stopping power, no fade, no vibrations or noise. But you do get a considerable amount of brake dust.
Old Feb 2, 2016 | 08:12 PM
Georgia8er's Avatar
Georgia8er
I really like Akebono pads. Very low dust, great stopping, no noise, and seem to be long life. Not cheap, but they work great.
Old Feb 4, 2016 | 12:17 AM
EDC8008's Avatar
EDC8008
I use NAPA's premium brand rotors and loaded calipers and never had issues on my own vehicles or when I did truck servicing.
Old Feb 9, 2016 | 09:55 AM
mushman's Avatar
mushman
I went with powerstop set up including calipers. I tow a 5th wheeler. These are the best by far brakes I have ever had.
Old Feb 9, 2016 | 01:07 PM
dkf's Avatar
dkf
I got Stoptech Cryos on the front of truck now with EBC Yellow Stuff pads. The rears have Raybestos R-300 slotted rotors on with Hawk SD pads. I had the R-300 and Hawk SD pads on the front too but had to replace them because of a decent amount of heat checking. Plus the R-300 did give a vibration in the front from new when braking. The Yellow Stuff pads do have more brake dust than the Hawk SDs and do bite better when cold. The SD has to have some heat into them before they really start to bite.
I'd at least go with the slotted cryo rotors on the front with either pad I mentioned. You don't have to spend the money on slotted cryo rotors for the rear. Also do a complete brake system flush and get new brake hardware for the pad install.
Old Feb 9, 2016 | 02:26 PM
smlford's Avatar
smlford
If you're into racing (like me) you have probably heard of Hawk pads. Some of the best in the business.
Here is a link to their super duty pads that I have and use when hauling my trailers. They last a long time and stand up to the rigors of heavy towing. I could not be happier!
Hawk Performance SuperDuty Brake Pads
Old Feb 11, 2016 | 06:46 PM
Misky6.0's Avatar
Misky6.0
Had to panic stop today when a sign fell down from the wind.
Never had front brakes ABS kick in before, normally it's always the rears that tend to use the ABS first. Stopped really quick and straight, very impressed.
Just over 1500 miles on my setup...
EBC yellow stuffs with Ford OEM rotors on all 4 corners.
I also did braided brakes lines, replaced all 5 rubber hoses, 1 at each caliper and the short one at the diff.
Old Feb 24, 2016 | 10:41 PM
DirtRacer96m
So I went with the PowerStop Z36 Severe Duty Setup front and rear with the Extreme Carbon / Ceramic pads. Kits K188936 and K190536. Got to say this deals stopping power is impressive .
Old Feb 25, 2016 | 05:40 AM
CollinsCD's Avatar
CollinsCD
Look's impressive. What brand of rear calipers did you go with?
Old Feb 25, 2016 | 07:42 AM
Irelands child's Avatar
Irelands child
I too have the Power Stop 'kit' on my '11 and pull pretty heavy. Way better then the stock arrangement - no fade. You do need to warm them up for 100% stopping power but even that isn't a problem as cold they seem as good as the Ford OEMs. If I had only replaced pads, would have used Hawk LTS as they have given me good service on other vehicles.
Old Feb 25, 2016 | 01:27 PM
BigMacWelds's Avatar
BigMacWelds
What's going on...
...with that front wheel setup? The offset looks like to be about six inches.
