Unknown engine miss
Old Feb 1, 2016 | 11:03 AM
Ronnief150man's Avatar
Ronnief150man
Unknown engine miss
The truck has 111260 miles on it.
It has no kick when gas pedal is put on floor. Only 1000 rpms from a dead stop to full acceleration* Engine slowly works it's way to full speed. When pulling out from a stop sign at normal throttle the truck does fine. When you come to dead stop on a hill and accelerate, the truck is sluggish even noticeable roughness in cab till you level out and then truck runs fine. The truck cruises at 65 mph no problem
Old Feb 1, 2016 | 11:10 AM
Ronnief150man
Sorry I guess you need to know the engine. It's a 351M/400 with 4 barrel carburetor.
Old Feb 1, 2016 | 09:45 PM
41505379's Avatar
41505379
Ron, Its kinda hard to figure out what your truck is doing. It sounds like it is not starting in low gear so it can't get the engine RPMs up at a start. Perhaps you have a shifting problem. Can you pull the shift lever to 1st gear at a stop and see if it takes off any better from a stop? Patrick
Old Feb 1, 2016 | 10:06 PM
Ronnief150man
The truck is not mine yet. I was told it might have a dead cylinder part of the time. The truck pulls out from a stop just fine on level ground. When you push accelerator to the floor it does not do what we used to call, "kick it in passing gear." The owner told me compression test n all cylinders showed 125lbs.
Old Feb 1, 2016 | 10:18 PM
Ronnief150man
Thanks for commenting. Let me brief you on what's been done to truck. New plugs, wires, new distributor new push rods, new lifters. New head gaskets. No valve job was done when head gaskets were replaced. No pvc valve attached to breather. Fine vapor of smoke coming out of pvc hole opening in valve cover after engine heats up.
Old Feb 1, 2016 | 10:45 PM
AK FORD GUY's Avatar
AK FORD GUY
It could be many, many things. If you get the truck, you would then have to start the systematic checking of all the possibilities.
To me, it sounds like a ignition / timing / carburetor problem.
Let us know if you get it and start this process.
Old Feb 2, 2016 | 05:13 AM
Ronnief150man
I've got another problem also. Turned hard right making a u turn and it died. Owner says when making a hard right turn engine dies. It does restart back after putting in neutral
Old Feb 2, 2016 | 11:44 AM
Ronnief150man
Thank you for your advice. The man just called and said he changed his and didn't want to sell. Reverse went out on transmission last night. I'll keep looking.
Old Feb 21, 2016 | 05:11 AM
Ronnief150man
There might be a chance
The transmission had water in it and now it locked in drive. I know it has to be rebuilt. Is it possible the transmission problem cause the engine to stall when making a u turn?
fpd7
2015 - 2020 F150
Mar 6, 2018 11:38 AM
Tjhunter-jeepman
6.7L Power Stroke Diesel
Feb 5, 2012 12:58 PM
SCscrew
2009 - 2014 F150
Aug 28, 2009 03:20 PM
justjames_76
Oct 15, 2007 08:58 AM
Black89F150
Sep 26, 2004 10:43 PM
