OEM Spark Plugs
Old Jan 31, 2016 | 07:03 PM
DOOM173's Avatar
DOOM173
Question OEM Spark Plugs
I'm getting ready to do an 100k mile tune up on my V-10.
Just got the truck in August.
I went to buy plugs today from autozone and they only had the Motorcraft PLATINUM plugs.
I'm assuming that the Excursions didn't come from the factory with platinum plugs, but that's all they had listed.
So is the OEM plug copper or platinum?
I will also be doing the COP connectors at the same time and going with Motorcraft as well. Just want to be sure I'm buying and using the right plugs!
Thanks.
Old Jan 31, 2016 | 07:31 PM
Bently_Coop's Avatar
Bently_Coop
Motorcraft Platinums are the ones to use.
Old Jan 31, 2016 | 07:38 PM
DOOM173's Avatar
DOOM173
So that's the OEM plug that came in the truck!?
Thanks for the response.
Old Jan 31, 2016 | 08:42 PM
LivingLarge's Avatar
LivingLarge
That's the one
Old Jan 31, 2016 | 09:51 PM
Bently_Coop
OEM/Motorcraft all the things.
Old Feb 1, 2016 | 08:35 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You'll have better luck at either the dealer or O'reilly, they sometimes carry OEM Ford parts. Autolite platinums are Ford's plugs before they slap the Motorcraft name on them.
Old Feb 1, 2016 | 09:48 AM
R&T Babich's Avatar
R&T Babich
So that's the OEM plug that came in the truck!?...
I don't think the OEM Motorcraft plugs are platinum.
The current replacement plugs, Motorcraft SP479, are platinum coated.
Here's an article about the coatings - Understanding The Different Types Of Spark Plugs
I've been getting my Motorcraft SP479 plugs from an ebay seller for $2.93/ea, no tax, free shipping.
You probably do not need to change the coils, just the boots.
I've been using the NAPA Belden 702418 boots with no problems.
I'm curious, when you change the plugs can you test the torque on them first?
The factory should have torqued them all properly, but have any started to work loose?
I'm guessing bank 1 may have some a bit loose and bank 2 will be fine.
We bought our 2002 with 103K which was running great, all original.
I was just getting ready to change the plugs after collecting the parts when #3 blew out at 108k.
I will be changing plugs and boots at 50k with a retorque of the plugs at 10k.
I just did our 2003 5.4L Exped at 151K and the plugs/boots were sad.
Jaime74656
13
Sep 17, 2011 05:21 AM
cargoflyr69
1983 - 2012 Ranger & B-Series
Jun 4, 2008 06:40 PM
jason86
1997 - 2003 F150
31
Oct 30, 2007 06:02 PM
calbery
Modular V10 (6.8l)
Oct 12, 2007 10:09 PM
FORDDIEHARD
Oct 30, 2006 11:55 PM
