Headlight brightener + LED bar
Quadratec pn 97109.1010 2 Spot / 4 Flood Combo 60 Watt 10" LED light bar
Because it is both spot & flood it can't be used with the low beams, plus I wanted to control it with the existing high beam switch. I also wanted to reduce, rather than increase, the load on the OEM wiring and shorten the electrical path to the headlights.
3) 25' spools of 12 ga wire, miscellaneous tie wraps, split loom, 2 relays with harnesses and these did the trick:
Wiring diagram attached as a pdf
2 relays on right inner fender
Longer 6mm bolts inserted into the stock battery clamps give an easy attachment:
