2000 7.3 blowing 30 amp fuse on cold start
Old 01-31-2016, 11:00 AM
stickandtin's Avatar
stickandtin
stickandtin is offline
Troubles started on cold morning starts. Truck would rough idle and blow white smoke for a minute then even out. Third day, got truck started, headed down road and motor died. Had it towed home. Thought it was CPS. Replaced it, still no start. Turned key on and noticed no fuel pump sound, no glow plug light and 30 amp fuse blown. Replaced fuel pump and fuse. Glow plug light came on, truck started, ran fine. Next cold morning, tried to start truck. Turned key on, glow plug light came on, truck tried to start then died. Turned key off then on again. No glow plug light, no fuel pump sound and 30 amp fuse blown again. I'm assuming glow plugs and fuel pump on same circuit. Anybody have any suggestions about what's going on? Where do I start? Thanks for the help. I should add truck has nearly 309,000 miles but has been well taken care of.
Old 01-31-2016, 11:03 AM
DISLFVR's Avatar
DISLFVR
DISLFVR is offline
Locomotive breath
Unplug the fuel bowl heater. It will run fine without.
Old 01-31-2016, 11:06 AM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
I agree with above post!
Heater is located on the bottom rear of fuel bowl. I've had mine unplugged for years. No problems.
Denny
Old 01-31-2016, 11:17 AM
stickandtin
Denny
Is the fuel bowl heater faulty and causing fuse to blow?
Old 01-31-2016, 11:21 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Yes, they can short and pop the fuse. When that happens, it also takes out power to the PCM.
Old 01-31-2016, 11:23 AM
HKusp's Avatar
HKusp
HKusp is offline
Yes, you can replace it if it bothers you not having it, but in the mean time, unplug it, replace the 30amp fuse, you should be good to go.
Old 01-31-2016, 11:25 AM
DISLFVR's Avatar
DISLFVR
DISLFVR is offline
Locomotive breath
If you want to you can replace it next time you change the fuel filter. Some like to keep it operational.
Old 01-31-2016, 12:46 PM
stickandtin
Thanks for the help. I'll give it a try and see what happens.
Old 01-31-2016, 01:31 PM
HKusp's Avatar
HKusp
HKusp is offline
Here it is from our friends at Riff Raff
Fuel Bowl Heater Element - Riffraff Diesel Performance
Old 01-31-2016, 05:30 PM
stickandtin
Unplugged fuel bowl heater, replaced fuse and truck started right up. Runs perfect. Thanks for the help!
Old 01-31-2016, 05:46 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
Yes, your fuel bowl heater if its the older design where it has three soldered contact points holding the wire element in place has had one of these points fail it will cause a short and cause the symptoms your describing, below is the updated part with part number that you need, once you replace the heater element with the updated one that SHOULD resolve the current issue
Dorman 904-210 Diesel Fuel Bowl Heating Element - Walmart.com
Dorman 904-210
EDIT: looks like HK beat me to it...
Old 02-02-2016, 09:34 AM
stickandtin
Truck starts right up every time. However on cold mornings still get white smoke on initial start up. What might be causing this? Are the glow plugs getting weak?
Old 02-02-2016, 06:34 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
How cold is it and how long do you leave them on? They say on for two minutes if it's really cold out and you don't try and start it. Some times you have to cycle the key couple of times. If it's really cold it will do this for a short time while warming up.
Azryael
42
09-15-2018 12:11 AM
tom2oo
05-12-2013 07:31 AM
78REDFORD
11-17-2011 04:04 PM
FroggF350
18
02-05-2008 12:11 AM
flatbed350Stroke
02-09-2006 03:55 PM
Quick Reply: 2000 7.3 blowing 30 amp fuse on cold start
