Quieting the PSD
Old Aug 9, 2003 | 07:07 PM
Nickiboy's Avatar
Nickiboy
Quieting the PSD
I realise that many PSD owners squirm at the idea of anyone wanting to quiet down their PSD engine........ But quite honestly I wish I could turn down the engine volume on mine just so I could listen to my favourite music on my stereo at times.......... So Im asking for ideas on how to turn down the volume, so to speak, on my 7.3 PSD without sacrificing a lot or any power for that matter................ Any ideas ???
Old Aug 9, 2003 | 07:14 PM
jschira's Avatar
jschira
Quieting the PSD
You need to do the in-tank and pre-pump mods.
These mods consist of eliminating/improving the factory fuel line quick connectors and fuel tank pick-up assembly to keep air from entering the fuel intake lines.
There has been numerous, lengthy discussion of these mods (there are a couple variations) in the 7.3 forum.
Make sure that you check the recent archive section (which ended July 3, 2003).
Grab a beer and start reading. It could take you several hours to get through all the threads.
Old Aug 10, 2003 | 01:11 AM
KING's Avatar
KING
Quieting the PSD
Raise the volume on your music. It can't get any simpler than that.
You folks make it too complicated with these so called "LOUD DIESELS"..........
Old Aug 10, 2003 | 01:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
Quieting the PSD
Up the hood and pour in concrete???
If they had a hundred pounds more of cast iron in the block it would be better.
Old Aug 10, 2003 | 01:34 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Quieting the PSD
What ever mods you do to the engine, it's still going to be a diesel (I'm one of the guys that likes that sound).
The only real answer it to better isolate the cab. Apply sound deadening material (like Dynamat) to as much of the inside of the firewall as you can reach, under the carpet, behind the door panels and above the headliner. Provided you never roll down the windows you'll think you're driving a towncar.
Sheesh! the PSD weighs almost 1000 pounds as it is!!
Old Aug 10, 2003 | 02:45 AM
Torque1st's Avatar
Torque1st
Posting Legend
Quieting the PSD
That cast iron is what makes the big diesels quiet(er). They can get away with that in the big trucks. They just reduced the weight as much as possible to run them in light trucks... -Then you get more noise Good old Engineering tradeoffs!
Old Aug 10, 2003 | 08:50 AM
johnsdiesel's Avatar
johnsdiesel
Quieting the PSD
Try using Standyne lubricity formula. My engine always runs a little quieter and smoother. A lot of guys who have done the HPX mod have noted a smoother, quieter engine.
Old Aug 10, 2003 | 09:16 AM
Mykro's Avatar
Mykro
Quieting the PSD
The meaner the badder the engines sounds the better I feel..
When I first start up my PSD in the morning there is nothing better in the whole wide world... Well there are a few things better, but I won't go there.....
Old Aug 11, 2003 | 08:30 PM
Nickiboy's Avatar
Nickiboy
Quieting the PSD
What exactly is the HPX mod ??
Old Aug 12, 2003 | 09:56 AM
RedTaurus94's Avatar
RedTaurus94
Quieting the PSD
My recommendation would be to drive a Dodge with the Cummins diesel for a few weeks, then go back to the Ford. Then, you'll realize just how quiet it really is......... :-)
Old Aug 12, 2003 | 04:34 PM
fisher_of_man's Avatar
fisher_of_man
Quieting the PSD
I have to agree with redtaurus94 on this one....you think your diesel is loud...man those dodges sound like they are completely wound up and they may only be going 10mph....kinda reminds me of the little honda and misubishi cars with the 6" in diameter chrome exhaust....too much noise for not enough power or speed!
Old Aug 12, 2003 | 05:44 PM
Nickiboy's Avatar
Nickiboy
Quieting the PSD
Damn BRILLIANT Man................ I woulda never thought of that one in a million years.
Old Aug 12, 2003 | 09:31 PM
ubon's Avatar
ubon
Quieting the PSD
Just roll the windows up??
Old Aug 13, 2003 | 12:12 AM
13hondacr250's Avatar
13hondacr250
Quieting the PSD
We have the same sort of problems with airplanes. Solution. Get an aviation headset with active noise canceling and get the kind that let you plug in your cd player. About 600 bucks.
Other solution, deal with it.
Old Aug 18, 2003 | 05:20 PM
Nickiboy's Avatar
Nickiboy
Quieting the PSD
Are there any good mufflers out there that can do the job without robbing the engine of power ??
