Shock choices for the ex
Hi guys, need some input
My 2003 ex v10 4wd has 60k and quite frankly the ride is harsh and bumpy. The factory shocks are original and still in. My primary use is just local and highway cruising. No off roading at all. My main goal is a smooth comfortable ride without the jarring blows to the kidneys ha-ha.
I've been doing alot of reading
I'm not a huge fan of bilstein I had them in a jag and they were unimpressive to say the least.
I'm thinking rancho 9000, kyb, or Monroe. Any others? From what I read the monotube oil filled design tends to be the smoother of the shock design.
Also would the rear hellwig sway bar help or what other mod can be done.
Hit me up looking to make some changes soon.
PS. I just put on 4 new Michelin ltx ms 2 tires
From the info you provided it sounds like not only are your shocks worn out but you are bottoming out on your bump stops. I would guess that at least one of your front bump stops is completely broken off. While you are crawling under the vehicle to check the bumps take a look at the springs, front the factory they were flat at ride height. Are they still flat or have they sagged and gone negative arch ?
Twin tube vs mono tube, neither design offers any engineering advantage for "smoothness"
Most new vehicles come with twin tube shocks simple because they are less expensive to manufacture in an automated factory.
mono tubes on the other hand lend themself to low volume production and is one reason many botique companies use that design.
Any of the shock brands you mentioned should have a quality shock valved to deliver the ride you are after.
WELCOME to the world of XXXs
Please add your general lo-cal to your profile. It's nice to know a members area.
PS: "Also would the rear hellwig sway bar help" NO it will not.
My buddy is the original owner of a completely stock ultra low mileage Ex and I occasionally take it out for a spin Even though I have driven many excursions both lifted and stock and have owned 3 of them total and 1 brand new one I still use his as reference to what the original ride was like since I can drive it occasionally rather then rely on what I recalled it was like 10 or 15 years ago.
That said as Harley pointed out they are leaf sprung solid axle vehicles and have the inherent limitations of those components but I would not say the stock suspension sucked, as a matter of fact in stock form it delivers a remarkably smooth and comfortable ride.
Because the Ex is a basic leaf spring and solid axle suspension it is simple to reconfigure the ride quality, ride height and even the payload handeling chartaristics.
Ill have to check the bump stops thanks for the idea. I know this beast is a solid axle but you literally feel eery little bump in the road. I think energy suspension makes a whole kit for 200 or so.
Some posters on here claim there ex almost rides like a caddy with some suspension enhancements. Id like to know what they did so mine can ride like that.
Will new springs help? Id like to keep the front and rear height even.
The energy suspension kit is a urethane bushings, great if your bushings are worn out but if you are looking for a "caddy" suspension I would stick with rubber bushings, they wear out quicker but are better at isolating vibrations.
New springs , when you went to look at the front bump stops were your springs sagging past flat like I described earlier ? If so then yes restoring the suspension travel back to spec is going to help.
To get that caddy like ride you want the lowest spring rate possible but also need adequate
Suspension travel. That was fords original goal so replacing your worn out suspension parts should give you the ride you are looking for.
Not the pickup shocks but their springs Doom. Ford short changed the EX to target it more to the Soccer Mom crowd, our wagons sit two inches lower than similarly equipped Super Duty trucks. Many of us have swapped in the truck springs to make the EX what it should have been from the start.
So all I need to do is replace my springs with F-250 super duty springs and that's it!??
a leaf springs arch is what determine the vehicles ride height and the spring rate determine its load capacity.
shock absorber, as the name implies do just that.
the spring swap difficulty is going to depend on the tools you have available.. Pretty sure there are step by step pics in the tech folder. If not search. It has been cover in detail
Thank you sir!
I'm starting to get a much better understanding of this beast I recently acquired!
Sorry for the noob questions. But I've already been bit by the mod bug! LOL!
