P0261 code
Old Jan 29, 2016 | 05:12 PM
fluidp's Avatar
fluidp
P0261 code
Hi all. the last couple days the truck has been a hard start in the morning. about 28 deg F. I thought the glow plugs were getting weak or a couple of them were out.
Hooked up my AE and pulled codes, one of them was P0261 # 1 inj.
Truck is fully warmed up and is running fine.
Did a koer glow plug test and it came back ok.
power balance looks good now. Probly looked different when I finally got it started this morning. Took 3 cranks to get her goin and it sounded like **** till it got a bit warmer.
Any thoughts??
Old Jan 29, 2016 | 11:47 PM
fluidp's Avatar
fluidp
any guru's want to chime in on this would be appreciated thanks
Old Jan 30, 2016 | 06:11 AM
WatsonR's Avatar
WatsonR
add a treatment of Archoil 9100.
What was the FICM at KOEO and while cranking?
Main battery voltage KOEO and while cranking?
Old Jan 30, 2016 | 02:52 PM
fluidp's Avatar
fluidp
ok just to note I had the block heater plugged in all night as the temp is 26 deg f
I disconnected the glow plug wire from batt
koeo: ficm 47.5, batt volt 12.5
cranked over batt volt 11.57, truck started right away, the ficm might have gon down a volt during cranking??
with engine running ficm 46 to 47.5
One more thing is I never got the p0261 code thismorning, yesterday when I got the code the truck was cold, not plugged in.
Old Jan 31, 2016 | 10:08 AM
Lrod617's Avatar
Lrod617
I'm no expert here, but I switched to Rotella T6 5w-40 with archoil 9100 and my truck starts and runs noticeably smoother at cold start. It's worth a shot to at least try Archoil 9100 for stiction problems. I tried it with 15w40 and could not notice much until I switched to T6 5w40.
Good Luck
Louie
Old Jan 31, 2016 | 03:24 PM
WatsonR's Avatar
WatsonR
The 5w-40 is full synthetic, less susceptible stiction.
Old Jan 31, 2016 | 03:39 PM
fluidp's Avatar
fluidp
Hi All. Ok id did a re test thismorning with the engine cold, Not plugged in temp is 30 deg f
KOEO ficm 47 v, batt 12.5V
Cranked engine and started FICM dropped to 40v ( or maybe lower since my AE will only read no lower then 40)
Let it idle for 5 min FICM went between 40v and 44v ant the last few seconds before I shut it down it reached 46v
I guess I need a new FICM
Any thoughts Please??
Old Jan 31, 2016 | 03:44 PM
fluidp's Avatar
fluidp
WatsonR, I have ran 15/40 non-syn sense new. I have had good success with non syn oil. at 240K I did all my inj seals, stand pipes and dummy's, oil rail seals, and havnt had a issue with anything HPOP related. change oil every 6-7K religiously
I do run 0w/40 in my old 7.3DI though
Old Jan 31, 2016 | 04:26 PM
Restlesswildman's Avatar
Restlesswildman
Well the FICM needs love!
How is your charging system health? Pull the Alt and batteries and head to your local box store and have all 3 tested! You might be surprised that you find issues there! 99% of the time the FICM dies because of the charging system.
#1 injector is easy peasey to do! My first injector was #5! That was a gem!
Oil change interval is a bit long! These things like fresh oil around 5k. 5w-40 is a nice addition to the engine. Run a round of Hot Shot diesel treatment with an oil change. It will get all the crude out of your engine.
Old Jan 31, 2016 | 05:01 PM
fluidp's Avatar
fluidp
Charging system is ok I monitor with my SGII 14+v when started and running warmed up 13.8 -.9
Batteries are new
I'm in Canada so my oil changes are done at 6000 -7000 KM not miles
Thanks for the info
Old Jan 31, 2016 | 06:22 PM
WatsonR's Avatar
WatsonR
At 40v FICM is toast. 5w-40 may give it a little easier starting, little thinner oil in the morning won't be as hard on it.
mrwalleyeman
Mar 16, 2019 06:02 PM
jeepzj94
Dec 30, 2018 10:37 AM
BuddyB
Nov 10, 2011 10:21 AM
YoungMT Hick
Dec 13, 2009 05:21 PM
overtime_ranchero
Jun 3, 2004 09:58 AM
