Larger Tires On F-350 Diesel
DOES ANYONE HAVE ANY INFO LARGER TIRES/RIM? I HAVE FOUND SOME GREAT 18" CHROME RIMS FOR MY TRUCK, BUT THE ONLY TIRES THAT WILL FIT ON THEM ARE 325/60/18. MY TRUCK IS CURRENTLY STOCK. I KNOW I WILL HAVE TO RAISE THE FRONT SUSPENTION AT LEAST . AM I LOOK FOR MORE TROUBLE THAN THEY ARE WORTH. SHOULD I STAY WILL A MORE IDEAL SIZE OF 295/75/16.
I have seen 33" diameter tires in 18's, which should fit at stock height. A big factor in clearance (from what Im told) will be the rim width. I was told you could go with a 35" tire with minor leveling if it was on a narrow (8") rim. Check out Nitto and Toyo tires. Also, if you have a Les Schwabb where you live, they have many more size options than Toyo lists on their website.
