No power bogging
Old Jan 28, 2016 | 10:33 PM
Jordo88's Avatar
Jordo88
No power bogging
Hello,
My 6.0 with 178k on it just started to have issues today. Low power. When I hit the pedal hard the motor revs ans the thr truxk barley moves. When I baby it it goes up to speed and shifts fine. Overall lacking power and not going anywhere. No CEL on. Turbo spools and seems to be ok.
Any ideas?
Thanks.
Old Jan 28, 2016 | 11:20 PM
FiveOJester's Avatar
FiveOJester
You are saying when you give it a lot of throttle the motor revs but the trucks doesn't move? Sounds like your transmission is slipping very badly. Check tranny fluid level, you might be low, but if its slipping that badly the tranny is probably toast.
Old Jan 28, 2016 | 11:28 PM
Jordo88's Avatar
Jordo88
When I give it gas it moves but not like it should. Transmission has never had a hiccup. Could it be a clogged cat?
Old Jan 29, 2016 | 10:36 AM
Mich6.0's Avatar
Mich6.0
is this driven every day, if not the unisom ring in the turbo could be sticking or worn grooves for turbo vanes. Any black smoke if so EGR valve could be stuck.
Old Jan 29, 2016 | 10:38 AM
Mich6.0's Avatar
Mich6.0
Is your truck a driven every day if not inisom ring could be sticking or EGR Valve could be stuck open
Old Jan 29, 2016 | 12:58 PM
Jordo88's Avatar
Jordo88
The truck is driven daily. I cleaned the egr valve and got a new ring seal set for it as well. Ran great then.
Someone mention EBP or icp sensor.
spinge
May 6, 2019 07:25 AM
cajunsuperduty
Feb 20, 2012 09:50 AM
BobbyB
Sep 1, 2011 09:17 PM
fireman_19
Aug 27, 2007 07:21 AM
bioPS
Sep 8, 2006 06:04 AM
