Undercoating
Old Jan 31, 2016 | 07:59 AM
scottscott's Avatar
scottscott
One VERY important thing to add to your truck: the plastic inner front fender liners like were used in the 77-79 trucks. Get the splash shields for the rear wheel wells too. Paint the front fender area inside as others mention, then pop the access plate off the cab mount. Spray motor oil inside there, & on the backs of the fenders. Then install the fender liners.
Old Jan 31, 2016 | 10:01 AM
paredneck33's Avatar
paredneck33
Another great product to look into is Fluid Film. It really is a great product. However it too is a once a year application, but only in areas that routinely see water. Such as the chassis of the truck. If you want to see pictures of how it performed after just one year of use check out this thread in the 09-14 forum. https://www.ford-trucks.com/forums/1...s-applied.html I should add that you can get tis product in both 1 gallon pails and in spray cans. I've priced the gallon pails with applicator gun for about $80 US. This product has even been known to stop existing rust dead in it's tracks.
Old Jan 31, 2016 | 10:08 AM
GLR's Avatar
GLR
I thought about doing this to my 75 but, never did. From the inside of the bed, over the wheel well drill a hole to get access to the area over the wheel arch (where they usually rust). Use air to blow out any Arizona sand or what ever has accumulated and apply whatever you might use, a rubber plug such as used by undercoaters can be used to fill the hole.
Old Jan 31, 2016 | 10:17 AM
paredneck33
There is no need to drill a hole to access that area. You can get to it from underneath the truck. Either just in front of the rear wheel, or just behind the rear wheel. And if you have a long bed truck you can access it from the top through the center stake pocket.
Old Jan 31, 2016 | 10:22 AM
GLR's Avatar
GLR
Forgot about the stake pocket (CRS) isn't there a hole in the bottom? Maybe that's why I never did drill mine...
Old Jan 31, 2016 | 10:48 AM
paredneck33
The bottom of the stake pocket is open. If you down into it you'll the top side of the outer wheel house. The piece often times referred to as the inner wheel house.
CapeMay609
2004 - 2008 F150
Aug 28, 2015 08:05 PM
78sharpshooter
28
Sep 7, 2009 10:47 PM
Equestriana
Paint & Bodywork
23
Apr 17, 2008 12:38 AM
caddylt1
Appearance & Dress-Up
Dec 3, 2007 08:49 PM
raytasch
Paint & Bodywork
May 7, 2006 02:54 AM
