Engine miss after using tow haul.
Old Jan 28, 2016 | 05:31 PM
bobv60's Avatar
bobv60
If I use tow haul going down a grade (empty) of a mile or so whin I come to a stop I have a hard miss at idle. A hard acceleration stops the miss and won't come back till I use tow haul again. Also get a code for cyl contribution 1 and 4. I am assuming a bad injectors, but just want to get another opinion
Old Jan 28, 2016 | 05:36 PM
npccpartsman's Avatar
npccpartsman
That should have nothing to do with towhaul. That's just coincidental. I think you're right on the injectors. have you checked your FICM voltage?
Old Jan 28, 2016 | 06:04 PM
bobv60's Avatar
bobv60
I thought the same thing, but it is VERY repeteable. Never happens with out t/h and about 50% with. Same roads. Only ting I can think is air from cyl gitting into fuel system.
Old Jan 29, 2016 | 03:22 AM
Yahiko's Avatar
Yahiko
If you want to come on up this next week and we can
run a scan on it with the Clone VCMII and the IDS.
Sean
6.0L Tech Folder
Old Jan 29, 2016 | 06:53 AM
bobv60's Avatar
bobv60
Thanks Sean, Don't know if I can make it, Lots of stuff going on. I might pick up a Snap on Modus I have been looking at and try that.
The FICM Volts stay right around 47.5 on the Live wire TS. The lowest I have ever seen is 46.
Old Jan 29, 2016 | 08:17 AM
Per4mance's Avatar
Per4mance
FICM time,I'll bet
Old Jan 29, 2016 | 03:55 PM
Yahiko's Avatar
Yahiko
You do know I have a Snap On SOLUS I am selling?
Sean
6.0L Tech Folder
Old Jan 29, 2016 | 06:47 PM
bobv60's Avatar
bobv60
No I didnt. What do you have and how much? The one I am looking at is a MODUS that has 13.4 software, a cart, keyboard, external monitor. The bad I'd the bottons on the modus so have to use keyboard and battery doesn't hold a charge. I can get for $700
Old Jan 30, 2016 | 02:07 AM
Yahiko's Avatar
Yahiko
I'll PM you.
About the only things it did not do was the Active Command
and power balance test. There are a few other things.
Sean
6.0L Tech Folder
Old Jan 30, 2016 | 02:01 PM
bobv60's Avatar
bobv60
Sean, Just found your post from '12 on Snap On diag website about doing the cyl balance test. It looks like the modus with 13.4 will do these tests and that is one of the things I am looking to do. Also need to do ABS unit brake bleed on GM products. I am going to look at it tonight. That IS a good deal on your SOLUS, but I don't think it will do everything I am looking for.
SnapOn MODIS EEMS300 scanner
Old Jan 30, 2016 | 03:30 PM
Yahiko's Avatar
Yahiko
A MODIS with Lab-scope module is what I replaced the SOLUS with.
I just need to get a new battery for it.
Sean
6.0L Tech Folder
Old Jan 30, 2016 | 03:49 PM
bobv60's Avatar
bobv60
Looks like I might need a battery also. Looking at online manuals it looks like there is a different plug in for power and a separate one for charging.
Old Jan 31, 2016 | 06:51 AM
dr67's Avatar
dr67
Are all your ground straps on the engine and Transmission in good condition and making good contact?
jimbo1969
Jul 19, 2016 03:28 PM
Yahiko
May 13, 2016 06:45 AM
Yahiko
Jan 17, 2016 05:37 AM
Yahiko
Jul 23, 2015 07:07 PM
