The owner before me had swapped the new transmission in. I have no idea what year or model it came out of but looks to be I need to find a 78 F-150 C-6 transmission
I think you are on the right track. A '78-'79 F-series C-6 should suit your needs. They will have the correct shift and downshift arms as well as the bosses for the NSS.
Make sure the one you get is for the correct engine family. C-6 transmissions don't have interchangeable bell housings.
Good luck
It's hooked to a 351 right now but soon it's gonna be hook to a early model supped up 460
When you swap in the 460 be sure to check the diameter of the snout (pilot) on the torque converter. 351M-400 and 460 typically have different size snouts.
