Strange blinker/blower issue
Old Jan 27, 2016 | 02:21 PM
nitruck's Avatar
nitruck
I have a 94 F350. Recently the turn signals and fan blower for the cab heat/AC stopped working.
Strangely I noticed that if I turned the car electrical on but didn't start the engine the blinkers and fan worked. If I started the engine they stopped working. Then I tried that again another day and it didn't work anymore.
Then just now after driving for a bit I turned the car off, then the electrical back on to roll up the windows, and when I did so the blower turned on again and blinkers worked. I started up the engine and they continued to work this time with the engine on.
To me this sounds like some kind of loose connection since it "doesn't make sense" in terms of working occasionally.
Is there anything else I might check that could cause this before I trace all the electrical?
Also, any specific electrical failure point that would cause both the blower/blinkers not to work but headlights/taillights/brakelights/reverselights/radio, etc, etc, etc all work? Seems very odd to me.
Old Jan 27, 2016 | 04:58 PM
Phy's Avatar
Phy
It sounds like the ignition switch isn't always returning fully to "run" after starting the engine...
Old Jan 27, 2016 | 06:37 PM
nitruck's Avatar
nitruck
Thanks for the suggestion, I'll try messing with it next time and see if it makes a difference.
Old Jan 30, 2016 | 11:00 PM
nitruck's Avatar
nitruck
Just wanted to provide an update on this, you were right Phy. All I had to do was push the ignition switch back a little to run and everything started working. You're a wizard.
Old Jan 31, 2016 | 11:17 AM
Phy's Avatar
Phy
Not a wizard, just been there/done that.
spikedog
26
May 19, 2020 06:30 AM
mwilliamshs
Mar 18, 2015 12:22 PM
ngng
6.7L Power Stroke Diesel
Jul 29, 2014 05:58 AM
weekendwarriorfsw32
6.4L Power Stroke Diesel
Mar 18, 2010 10:29 AM
ron d
Jun 24, 2007 06:45 PM
