Dash conmand ?s
Old Jan 31, 2016 | 08:15 PM
coax9952's Avatar
coax9952
I'm pretty sure you're supposed to connect the unit KOER "Key ON Engine Off", Launch the program, Then start the vehicle.......You can't change things once everything's running. It will always kill the engine.
Old Jan 31, 2016 | 08:19 PM
jed1894's Avatar
jed1894
Got it. Makes sense
FiznUKa's Avatar
FiznUKa
Validate the Pid's after you set up the vehicle. Also go to settings and check what OBD interface type is set up as. I use an elm so that is what it is set as.
Old Jan 31, 2016 | 08:22 PM
FiznUKa's Avatar
FiznUKa
I have never had that problem. I have selected new PID's while running. I also start the truck then select the app.
Old Jan 31, 2016 | 08:23 PM
jed1894's Avatar
jed1894
Well, it seems to be an iPad vs iPhone issue. Just downloaded app on my iPhone6 and it works. Still won't recognize the truck with iPad. Operating software on iPad is old. iPhone newer. So that must be it.
Guess it's useless now unless I spend another $10 for the Ford specifics I guess ?
Old Jan 31, 2016 | 08:26 PM
FiznUKa's Avatar
FiznUKa
Shouldn't have to buy the ford bundle just add the phone to your Palmer acct. in other words log in to the account on the phone in the app and add the phone.
Old Jan 31, 2016 | 08:35 PM
jed1894's Avatar
jed1894
Just did that. Still shows $9.99 if I get the Ford bundle
Old Jan 31, 2016 | 08:42 PM
FiznUKa's Avatar
FiznUKa
It's been a while since I had to do it. At that time I had an iPhone 4 and 5 and it asked if I wanted to add this phone to the account. Maybe they changed it. Odd
Old Jan 31, 2016 | 08:47 PM
jed1894's Avatar
jed1894
No, I can add the phone with no problem. I thought you meant I could get the Ford bundle at a lower cost. Looks like in order to get Ford specific PIDS, I need to buy the app buy on for $10
Old Jan 31, 2016 | 08:48 PM
FiznUKa's Avatar
FiznUKa
Just downloaded it to my iPad and it asked if I wanted to add the device I said yes and the purchase was there.
Old Jan 31, 2016 | 08:50 PM
jed1894's Avatar
jed1894
Yep. I think I just misunderstood you. Thanks for all the help. Guess I will buy the add on and start playing with it
Old Feb 1, 2016 | 08:35 AM
nossliw's Avatar
nossliw
Good thread. I have had dash command for years, mainly use it on gassers and not the diesel. I also have Palmer performance's laptop soft ware as well. That being said I went through a couple of months trying to get them to jive with the 7.3s without luck. They kept telling me their software works fine with the 7.3...and it did not. Didn't matter if it was on my iphone, ipad, or Windows computer, it would connect I'd set the parameters and nothing showed up.....
Curious if their Ford bundle fixes this issue? Obviously you have it working and a dashboard up! Please tell me more as it sure would be nice to actually use it for what I originally intended it for!
Regarding shutting off the truck, I forget the setting you need to unclick in the pids, I am not sure if its auto connect or auto reconnect, but this needs to be unchecked and that issue will go away. I had it happen going down the highway at 70...
Look forward to hearing more! I just found out their latest update got rid of the old Kiwi ELM I was using...now I have to go buy a KIWI 2....Effing stupid
Old Feb 1, 2016 | 08:53 PM
  #28
jed1894's Avatar
jed1894
I emailed tech support and they told me to disable "OBDII Mode $09 support." I'm assuming that means make the little slider green because it was not green when I checked it.
Old Feb 1, 2016 | 10:33 PM
  #29
FiznUKa's Avatar
FiznUKa
Did they say what the mode support is for because mine is not green and it works.
Old Feb 2, 2016 | 06:19 PM
  #30
jed1894's Avatar
jed1894
They have not responded to email yet. Maybe they are tired of me asking questions.
ChiefM
Apr 1, 2012 01:33 PM
rolltide3006
Jan 14, 2011 06:57 PM
fatforty
Jun 18, 2006 10:17 AM
AF Mezkin
Appearance & Dress-Up
Feb 2, 2005 01:07 AM
neodragon
1983 - 2012 Ranger & B-Series
Sep 21, 2003 05:19 PM
