Cam bolt
Old Jan 25, 2016 | 06:36 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Cam bolt
Should there be a bolt in the cam to hold the gear in place? It's been so long since I dropped my core at the machinist I can't remember if there was one when in the cam. Can't find anything that looks remotely right in the box o' bolts from when I broke the engine down and the other 300 I'm cannibalizing for parts didn't have one when I pulled the timing cover. Not necessary with a pressed on gear?
Old Jan 25, 2016 | 07:00 PM
AbandonedBronco's Avatar
AbandonedBronco
No sir. I don't think you'd have enough between cam and the timing cover if you did.
Old Jan 26, 2016 | 07:33 AM
The Frenchtown Flyer's Avatar
Sometimes racers put a bolt in there to bear against the cover to keep the gears from "walking" back and forth, but that requires that the head of the bolt be turned down. That tapped hole is useful for installing the cam if you thread a long bolt into it to use as a handle to insert the cam into the journals.
Old Jan 26, 2016 | 06:42 PM
BaronVonAutomatc
Thank you, gentlemen.
Firstn10
Modular V10 (6.8l)
Nov 25, 2018 04:29 PM
wezol5484
18
May 5, 2010 11:25 AM
badazzbeatbird
Mar 23, 2007 07:46 AM
broncky
Feb 24, 2003 11:34 AM
