Question about Regen
Old Jan 25, 2016 | 03:23 AM
Nipperdog's Avatar
Nipperdog
When the Truck goes into Regen at normal driving speed and the truck gets stopped at a light, does the regen stop when the brakes are applied. Does it resume when the truck moves again............Lew
Old Jan 25, 2016 | 05:13 AM
djousma's Avatar
djousma
It continues. I'm pretty sure it only stops if you put the truck in Park. I've watched plenty occur in Torque Pro.
Old Jan 25, 2016 | 05:16 AM
Just Strokin's Avatar
Just Strokin
The simple answer is no, it does not stop when you "pause" for a red light. The ECU knows when you are stopped and moving at speed regardless of the speed. It takes all this into consideration as to whether to continue or stop the regen process. The ECU will process the parameters (which I do not know) and determine whether you are traveling fast enough to complete regen or to terminate it. The ECU will either restart the regen or delay it till later should you stop and idle longer than the parameters allow or shut the engine off during the regen process.
My thoughts, just drive the truck and not worry. If the DPF gets too much soot and does not complete a regen to resolve this, it will give you a message such as "EXHAUST OVERLOADED DRIVE TO CLEAN" or "EXHAUST AT LIMIT DRIVE TO CLEAN NOW". These messages are important and you should drive the truck to complete a regen or have a method to do a manual regen.
Old Jan 25, 2016 | 06:04 AM
Nipperdog's Avatar
Nipperdog
My thoughts, just drive the truck and not worry. If the DPF gets too much soot and does not complete a regen to resolve this, it will give you a message such as "EXHAUST OVERLOADED DRIVE TO CLEAN" or "EXHAUST AT LIMIT DRIVE TO CLEAN NOW". These messages are important and you should drive the truck to complete a regen or have a method to do a manual regen.[/QUOTE]
Ok Thanks for the info guys. I never have got a message to "Drive To Clean", but it seems that the Regen pattern on the new 2016 is different than my previous 2011 6.7. Just hit 4K Mi and all is well. Just curious about the Regen characteristics of the Gen II engine.
Old Jan 25, 2016 | 09:34 AM
donovan's Avatar
donovan
Regen
One short light does not seem to cancel the Regen but lots lights with stop and go traffic does stop the regen. But like other have said Don't worry too much about it.
Old Jan 25, 2016 | 03:45 PM
MPD56's Avatar
MPD56
My Regen will time out if I'm too long at a railroad crossing or waiting in a drive through.
Old Jan 26, 2016 | 04:13 AM
Rattler1's Avatar
Rattler1
I was waiting at a drive through the other day while mine was in regen. It stayed on for 6-8 minutes without being in park - I left it in gear intentionally since my last 2 or 3 regens had only been partially completed. It got down to around 1.2 gpl and 11% dpf load when the regen stopped. It was very obvious by the sound of the engine that the regen stopped - it went from a higher pitched jet engine type of sound to a deeper throaty diesel engine rumble. As I drove it the numbers went down even more to 1.01 gpl and 4% dpf load. Then they started going back up like normal.
Incidentally, it had started the regen cycle at 2.32 gpl and 77% dpf load - I presumed it had started earlier than the normal 3ish gpl and 100%+ dpf load due to the several partial regens earlier.
Old Jan 26, 2016 | 06:55 AM
Ricohman's Avatar
Ricohman
I used to worry about all this.
Now I just drive and let the truck do what it wants as it will anyway. You can't really tell if its in a regen unless you are watching the fuel consumption.
Old Jan 26, 2016 | 06:03 PM
kper05's Avatar
kper05
Park and neutral will stop an active regeneration after 10 seconds. It will not stop if you are simply passing through neutral to reverse then back to drive, for example. I can reproduce this any time I'm in an active regen. Of course my knowledge is on a 2011 like your old one.
Old Jan 26, 2016 | 07:05 PM
FatOldGuy's Avatar
FatOldGuy
I've heard others say this too. I guess my 2016 is different... I can tell when mine goes into regen. The sound of the engine changes and sometimes I can feel it. I rarely drive with the radio on, or any thing else that would make much noise, so I can easily notice the change in sound unless I'm on a hands free phone call or something. Even when the wife is riding with me, I'll ask he if she notices. Sometimes she does, sometimes not.
Old Jan 26, 2016 | 07:21 PM
kper05's Avatar
kper05
Same here but not just the newer ones. I usually know when mine enters active regen. It wasn't always that noticeable though but as the engine has become older, it has become a little louder. I use the radio about 60% of my drive time and I can usually hear the tone of the engine change or I'll catch it at a stop since the idle is different. If I don't hear it, the chances are high that I'll eventually see the red R on my CTS screen. It's rare that I see the dash message.
Old Jan 26, 2016 | 07:46 PM
FatOldGuy's Avatar
FatOldGuy
Ditto that.
Old Jan 26, 2016 | 11:24 PM
MPD56's Avatar
MPD56
Interesting!!
I found that there is a lot of conditions that start and stop Regens. I also think that the last Flash recall done to my 2013 has changed some values and I'm going to have to change the equation for the Soot PID.
Old Jan 27, 2016 | 10:59 AM
SHOpar's Avatar
SHOpar
I've found it interesting to watch when the truck decides to go into regen. The other weekend it decided to kick in as I was leaving the mountain after a day of skiing. It was a 35 mile drive into town for dinner, but all downhill and 30-35 degrees and snowing. The truck never came all the way up to temp, so I knew that regen wasn't successful.
If the regen would have waited to trigger until after the dinner stop, it would have had 60+ miles of 70 mph freeway driving to get a good cleaning in, but when does it decide to start up again? The next morning, when I'm only 5 miles from work. I have yet to get the "DRIVE TO CLEAN" message even with all the interrupted regens, so I haven't been too worried about it.
eZAK
Feb 27, 2019 03:44 PM
blue oval fan
6.7L Power Stroke Diesel
39
Jul 25, 2017 04:53 AM
harley scott
21
May 5, 2013 03:19 PM
Bubba6.4
6.4L Power Stroke Diesel
25
Jul 24, 2012 04:45 PM
Noah2010
18
Mar 9, 2011 10:18 AM
