2002 f-150 xlt, trailer harness problem
I have a 2002 F-150 XLT with what appears to be a factor installed trailer harness (4 terminal plug). I'm not getting any lights to work on any trailer, seems there is no electric current from the connector. I can't find any fuse problem and as far as I can tell the wiring harness appears to not have any damage. I need a fresh start to trouble shoot it but am not familiar enough with this type of wiring harness to know where to start. I don't even know where there is a connection for it. Any helps or tips would be greatly appreciated. I have installed plenty of packaged trailer harnesses but this is a bit new to me. Standard wiring colors are no issue. Finding where it is not making electrical contact is the issue.
Something crazy going on. The tail lights are working. I checked at the harness connector near the driver's side tire. Got power there from flashers. No power to terminals on end. When I checked wire colors, voltage and continuity of terminal harness the wires do not correspond to the "Hot wires" on the female end of wiring harness from truck. The colors for brake/turn signals are yellow & green. The color of wires on the truck harness female end appear to be green/red and (my sight is not good) either orange or red and blue or purple.. they're upside down to where they should be. Not sure if there is a problem somewhere else or if I should just cut and tie wires together to make it work or what. I hate to jerry rig things....
About page 205 in your operators manual it should show the fuses. I think #19 and #20 in the box on the left fenderwell are for the trailer running lights. Also check the breaker and fuse that Bluegrass mentioned above... THe truck harness at the spare tire left side should have several wires in it. The rear harness to the tail lights and 4 prong trailer plug will have a couple less wires. The wires missing will be the brakes and battery charge for the optional trailer feed for 6 or 7 prong plugs .... You should be able to trace the 4 prong wires up to the plug by spare tire. Should have voltage on one when running lights are on, and another when brakes are on.. Make sure you have a good ground wire !! If no power, then look up front at the fuses.
dawhits1
29
07-07-2021 08:27 PM
Jay Judkins
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-03-2015 05:53 AM
