I'm ordering my PMF RSK and I need to order shocks as well. I am getting the smallest lift RSK (2.25 I think) and I plan to run the U code SD springs since I have a 460 in my truck. If those springs add lift then I need to potentially go up to the next length of shock. And besides the adjustable track bar, is there anything else I should consider adding to my list?
I appreciate any insight here.
Lift over what?
the PMF kit was designed to use SD length spring, not necessarily for a specific rate. the 2.25" is the drop of the spring mounting points
Plan on using longer than stock shocks no matter what SD spring you are using.
I really like the way it sits. I'd like to get my front up. Not quite sure how to do it without sacrificing the ride I've already got with adding a leaf. There must be a taller spring that has a same as stock ride.
If your F-250 still has the TTB, just swapping a solid axle in will lift it about 2 - 3" (you need to switch to F-350 springs with the solid axle, F-250 springs are stiffer than F-350 springs due to the TTB giving the tires leverage against the springs). A solid axle swap and a reverse shackle kit will raise it about 5".
If you want to keep the TTB and lift it you probably need to get a lift kit. Only springs without swing arm drop brackets will screw up your steering geometry.
