4.6 Liter - Intake Manifold Runner Control
So I just installed a fresh 4.6 long-block in my '98 4x4 xlt and I have a noise coming from the manifold area. Thought it was possibly valves or timing chain. Took it to dealer and they diagnosed it as the Intake Manifold Runner Control. Never heard of it!!! Problem is, I can't find that part for this motor. Is it inside the intake? Do I have to replace the whole intake? Dealer didn't tell me, once I said I would do the work myself.
If the motor has it, it hangs under the intake in the block valley.
If you can look down behind the alternator, under the intake, you may see the electrical connector on it's front.
That runs the motor to open/ change the air path.
This large Plenum is insulated for heat rejection.
If it got cracked some how, it will leak outside air, in.
Good luck.
Good luck.
HonokaaHi
General Automotive Discussion
05-02-2017 01:40 PM
Emerald Navi
1997-2006 Expedition & Navigator
11-07-2013 09:48 AM
Green Streak
01-09-2006 09:23 AM
