Front spring shackels
Old Jan 21, 2016 | 12:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by harley4jcs
You don't need to swap springs What you gona do Swap them again this summer for the beach trips ??? Your springs will handle the plow just fine. You just want to level your truck, BIG difference.
He doesn't spec what bumpers he has but if it is a typical fabricated style bumper that is what, maybe 500 pounds, 8' plow runs 800 pounds , so I would argue 1200 additional pounds on the nose of the Ex warrants a swap to different spring rates.
Put it this way, a 7.3 diesel motor weighs about 1200 pounds. I think we can all agree the addition of a 7.3 engine on your grill is going to take more then some spacers to achieve the ride quality you expect.
Old Jan 21, 2016 | 02:01 PM
ithaca1230's Avatar
ithaca1230
I did consider removing the extra leafs from the B rear springs but they work great the way they are now. The Bumpers Front and rear are Roadrhino very similar to road armor bumbers. With the winch I say they are under 300 lb. Two guys can pick it up. All the comments really help me figure out what I'm gonna do.
Old Jan 21, 2016 | 02:32 PM
harley4jcs's Avatar
harley4jcs
Originally Posted by pirate4x4_camo
That's cool, they are not need .... Until they are needed
Well said.
PS: After I thought about it, I was not 100% truthful.
I run bump stops on my shocks & love them.
Old Jan 21, 2016 | 05:14 PM
pirate4x4_camo
300 with the winch is probably close to accurate.
Old Jan 22, 2016 | 07:14 AM
ithaca1230's Avatar
ithaca1230
With the current set up the truck does not bottom out on the bump stop. I have not noticed it bottoming out with the plow attached. It still has room between the axle and stop with the plow attached. I usually have 600-700lbs salt in the back as ballast.
Old Jan 28, 2016 | 10:18 AM
brycez28's Avatar
brycez28
How about firestone air bags? I don't have a plow on my Ex, but it came with air bags. Each bag has its own inflation valve, I get a couple inches of lift with it at 20psi.
Old Jan 28, 2016 | 10:46 AM
holeshotwalt's Avatar
holeshotwalt
I would just install a 2" drop bracket kit. That'll give you the height without killing the ride. Cary at CT Performance (one of the originators of the V/modified B idea) has the drop bracket as part of the original 'kit'. It matches the front height to the modded B springs.
You can decide to leave or remove the 3rd leaf afterwards.
Old Jan 28, 2016 | 02:49 PM
ithaca1230's Avatar
ithaca1230
Was gonna call them next week.
Old Jan 28, 2016 | 03:00 PM
holeshotwalt
With his years working on Excursion suspensions, he is The Man; seen and heard it all I believe. He'll get you squared away. Tell him ya heard about him here!
Old Feb 11, 2016 | 01:12 PM
wrxin's Avatar
wrxin
Has anyone found just the front drop brackets? I have "lift shackles" already but I'm looking around for the drop brackets.
ithaca, did you have any success? I bought lift shackles off ebay a few years ago and they worked great. They say something like 2" lift but that doesn't mean they are 2" long, they are much longer than the factory shackles. You'll need longer swaybar endlinks too if you don't have them already.
Old Feb 11, 2016 | 02:08 PM
holeshotwalt
Call Cary Home
at CT Performance!
Old Feb 11, 2016 | 04:13 PM
holeshotwalt
These guys have great stuff too:Individual Components and Upgrades
Old Feb 12, 2016 | 10:18 AM
  #28
wrxin's Avatar
wrxin
Originally Posted by holeshotwalt
Call Cary Home
at CT Performance!
Thanks for the tip. I had a very confusing conversation with him, part of it was my fault, but they don't offer just the hangers.
He said he'd never heard of anyone using lift shackles.
Old Feb 12, 2016 | 10:20 AM
  #29
wrxin's Avatar
wrxin
Thanks, I stumbled across them yesterday. Among other things, they have some pretty cool lift blocks.
For some reason, it's very hard to find just the drop hangers. People sell shackles and hangers but not just hangers. Might be time to break out the welder...
brian1080
Jul 5, 2014 11:59 PM
PatsPOS
Apr 7, 2013 08:00 PM
cowboyty
Nov 10, 2006 06:11 AM
mtgrzlyman
Offroad & 4x4
Feb 20, 2006 02:08 PM
