Transmission bolts Striped
Old 01-19-2016, 09:22 PM
Lee Baldyga's Avatar
Lee Baldyga
Lee Baldyga is offline
The top bolts are striped and won't brack loses what do I do 97 ford ranger 2.3. 5 speed
Old 01-20-2016, 11:38 AM
Hank85713's Avatar
Hank85713
Hank85713 is offline
which are you referring to, in the trans or the engine block? If wont back out try to get a pry bar end under the head, apply a little pressure as you back them out. Once out you will need to helicoil or something simular to repair if in aluminum.
Old 01-25-2016, 02:48 AM
CBB9M's Avatar
CBB9M
CBB9M is offline
Weld a socket to each bolt with a rounded head then remove.
rbond
21
10-18-2020 09:25 PM
ihf-350
06-02-2015 05:58 PM
1948 F1dude
06-01-2013 08:32 AM
snipa
08-16-2009 11:17 AM
Ed Wagner
04-14-2005 10:05 PM
Quick Reply: Transmission bolts Striped
