Who makes the best distributor. MSD, mallory, HEI or other brands. ive heard HEI distributors suck after 4500 rpm. I've heard MSD is either the best or it's the crappiest. anyone know which brand is the best?
No, HEI units don't "suck" after 4500......MSD has been through bankrupcy & buyout...would wait till things settle over there.....Ive never been that big of a fan of their products for street use.
OEM distributors are excellent with proper tuning.....
Like Beech said OEM distributors are actually the best bet. If a new distributor is needed, look into Performance Distributors.
What are good performance distributors? You know my build. Will an OEM distributor be just as good as an MSD or should I go with MSD or a different performance distributor?
It's up to you. Some of the components in the Cardone may not be a good quality. Is there something wrong with OEM one?
The one that came off of the engine had oil beneath the rotor under the cap so that thing is toast. I figured a reman distributor would be best if I'm going oem.
That's just an o-ring replacement......get a distributor rebuild kit.....cheap, easy sure fire.
Agreed, that's not a big deal. You may check into seeing if Performance Distributors can rebuild yours. I know they sell complete units but I think they also do rebuilds.
