6.0 Please Help
Old Jan 21, 2016 | 12:11 PM
  #31
WatsonR's Avatar
WatsonR
program this into the scan gauge
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
How many codes does it come back with... 1,2,3,4,?
If it comes back with codes, it will need to be read.
Old Jan 21, 2016 | 01:08 PM
  #32
mini-x fan's Avatar
mini-x fan
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
I will program that about 2:30 when I get out and report back.
Old Jan 21, 2016 | 02:41 PM
  #33
mini-x fan's Avatar
mini-x fan
I have 2 DTCs
Old Jan 21, 2016 | 02:56 PM
  #34
WatsonR's Avatar
WatsonR
Great... now we're getting somewhere... you need to take it to AutoZone/Advanced and read those codes.
One of them should be P0401
Old Jan 21, 2016 | 06:07 PM
  #35
mini-x fan's Avatar
mini-x fan
I have 2 DTCs
Autozone didn't pick up anything. They said it would only pick up if the CEL was on
Old Jan 21, 2016 | 10:51 PM
  #36
04badford's Avatar
04badford
VGT looks good so far, monitor these when driving just to what it does when the truck acts up , by chance did you write the DTCs down ? If so post them up and I'll get right on it, just got home from a long drive work week Blaaaaaaaa , lol
Old Jan 22, 2016 | 12:03 PM
  #37
mini-x fan's Avatar
mini-x fan
It is still showing 2 DTCs but autozone didn't pick anything up. They said it would only pick it up if the CEL was on.
Old Jan 22, 2016 | 12:25 PM
  #38
WatsonR's Avatar
WatsonR
take it to another place... they lied
Old Jan 22, 2016 | 01:12 PM
  #39
mini-x fan's Avatar
mini-x fan
I'll hit advance on the way home.
Old Jan 22, 2016 | 04:47 PM
  #40
Rusty Axlerod's Avatar
Rusty Axlerod
It's kinda ironic that the ScanGauge skips so many codes but is generally accurate on the DTC count. If you scan with a good computer based program, you'll see almost every truck has a soft code of some sort, "U" series body codes, CAN error codes, ignition switch errors, 4x4 codes on transfer switch or solenoid. Most of the handyman scanners at the parts store (even the more expensive ones) don't show these codes either for whatever reason. I suspect DTC count is a generic data point so ScanGuge shows the correct value there but doesn't have the power (protocol- doesn't speak the language) to communicate with all the modules and retrieve the actual code.
It may take a very good diag device to get the codes only to find they aren't related to the issue you're working on.
Old Jan 22, 2016 | 09:48 PM
  #41
mini-x fan's Avatar
mini-x fan
I will have to get the codes run tomorrow. My brakes went out completely in the school parking lot so I had to limp it to a shop. It's always something
Old Jan 24, 2016 | 06:45 PM
  #42
mini-x fan's Avatar
mini-x fan
They were ABS codes. I checked my ICP voltage and IPR and they are both spot on. I also changed my fuel filters. I don't get it...
Old Jan 24, 2016 | 10:08 PM
  #43
04badford's Avatar
04badford
Have you checked for wire chaffing, lots of places for wires to rub on through the harness , one of the issues that ford didn't get right , any way start with the ICP connection with engine running do a pinch and wiggle once you hear the engine stumble Bam you got it. Other wise a Contribution test for the Injectors is the next step, even though the ICPV is showing good it's when the wires get heated is when they start showing signs.so make sure engine is at least warm when testing . ( be safe ).
Old Jan 25, 2016 | 09:32 PM
  #44
mini-x fan's Avatar
mini-x fan
Hooked it up to a diagnostic computer today and everything was good including injectors. My friend plugged his SCT into my truck and put a different tune on my truck and so far so good it's like a brand new truck. He's going to let me run it for about a week to make sure but I think my tuner is the problem.
Old Jan 25, 2016 | 09:39 PM
  #45
04badford's Avatar
04badford
I should have read closely , I didn't know you had a tune, yep they can be a pita, glad your back up and running, what brand of tune is it?
