fuel question
Old Jan 17, 2016 | 07:09 PM
blackfords's Avatar
blackfords
fuel question
Hi all. I filled three brand New fuel cans In July 2015 with ps and diesel. My question is should I put this in my truck being 6 months old or do you think I should save it for my brush fire?
Old Jan 17, 2016 | 08:05 PM
System's Avatar
System
Prolocutor
The fuel should be just fine. I did the same at the beginning of RV season. I have an anemic 26 gallon tank so I filled a spare 5 gallon can in the beginning of the season for RV trips to new locations where fuel stops were uncertain. Poured it in the truck at the end of November. No issue...
Old Jan 18, 2016 | 10:48 AM
Rattler1's Avatar
Rattler1
It will be fine as far as fuel potency. It may have lost a little pep but probably won't be noticeable.
However, you may not have any anti gel properties if you live in a coldet climate.
With that in mind I would either add some anti gel if you dump it all in your tank at once or only dump one can in per fill up to benefit from the fuel coming fresh from the pump.
CPB1
May 8, 2013 09:59 PM
Opossum
Dec 25, 2012 06:35 PM
crazer42
Oct 20, 2010 06:54 PM
steevo152
Feb 16, 2010 03:57 PM
jakeharp
Dec 16, 2004 03:35 PM
