Too Much Fuel Treatment ?
How much is too much fuel treatment
Im using that 'service plus cetane boost' fuel treatment. My area can get down rite cold and i was concerned about gelling. The bottle treats 100 gallons of fuel per 32oz bottle.
Should I follow that scale or would it hurt to put more in the tank at fill up. How much is too much. Would pouriing all the 32oz into my 29 gallon tank at fillup hurt my engine ????
To answer your question directly- NO. It won't hurt a thing. If you do run this much, however, make sure you put the additive in on a nearly empty tank at fillup (with the engine off) and fill up before you start the truck, in order to make sure it is well-mixed.
on
Some of the additives like PRI-D will work better if added per PSD's instructions above and then given a bit of time to chew on the fuel. I.e., drive it home with the newly full tank of fuel and park it for a few days.
PRI-D claims to work on the molecular stucture of the fuel and breaks up clumped molecules so it takes some time for it to do that.
white Buffalo
90
10-27-2015 04:01 PM
