w/ the 89 f150, 5.0 that won't start. bought a sunpro code scanner but can't decipher the flashes they aren't as they should be according to the directions that came w/ the scanner or the haynes manual. the flashes are very erratic. any thoughts out there in fordland?
hey bro.i used a volt meter and had to sit in the truck and write down every flash as stated. i marked each flash as strokes that go in rows.(1) first set of flashes'''''' then
second set ''''''then
third set '''then
and so on. do this acouple of times on diferent pages then when you think you got the correct ammount of strokes(codes) then post the codes here as the amount of strokes(flashes) and i am pretty sure steve will come rescue you from there.
goodluck bro!
