grinding sound
Old Jan 31, 2002 | 07:39 PM
Ryan50hrl's Avatar
Ryan50hrl
grinding sound
when using 4x4 on my 95 F-150 at highway speeds 45-55 mph it works and sounds fine while on the gas...but when i let off the gas and coast a horrible grinding type of noise comes from the front end...i'm fairly sure it's not the hubs since it did it with the auto hubs and two weeks ago i swapped them out for warn premiums. Any ideas would be appriciated.
Thanks
Ryan
Old Jan 31, 2002 | 08:08 PM
explorerxlt94's Avatar
explorerxlt94
grinding sound
It could possibly be the wheel bearings, did you replace them when you did the hubs?
Justin
Old Jan 31, 2002 | 09:35 PM
Ryan50hrl's Avatar
Ryan50hrl
grinding sound
It only does it when 4 wheel drive is engaged...in 2 high it is fine,,,which leads me to belive that its not the bearings.
Old Jan 31, 2002 | 10:10 PM
madman666's Avatar
madman666
grinding sound
It could possibly be the u-joints, I’m thinking about the ones in the front drive shaft. I’ll bet you already replaced them, but it’s a possibility,
It could also be the front axel u-joints, there are three of them buggers, I can’t think of any thing else.
I’ve also heard of it happening after the conversion to manual hubs in some situations, but dot remember why.
Old Jan 31, 2002 | 11:35 PM
Ryan50hrl's Avatar
Ryan50hrl
grinding sound
i actually haven't replaced the front u-joint...that was going to be my next idea. It did it before the manual hubs too. so i'm pretty sure it wasn't the conversion.
Old Feb 1, 2002 | 01:39 AM
brett_d's Avatar
brett_d
grinding sound
I would second the notion on the front driveline u-joints. If the noise gets louder or changes when you turn then it may be the front axle u-joints..
Old Feb 8, 2002 | 09:18 PM
edenroadmaster's Avatar
edenroadmaster
grinding sound
this may sound dumb, but check the transfer oil. with a leaking seal, the level may be low
Old Feb 10, 2002 | 12:11 AM
Ryan50hrl's Avatar
Ryan50hrl
grinding sound
Well now i'm really mad. It has started to do it in 2 hi. when coasting off a highway onto off ramps and such. Its not nearly as loud as in 4wd, but none the less, its still there. I'm going to check the transfer case tommorow, i did replace the seals on it not too long ago, but i'm fairly sure i filled it correctly and its not leaking. Well, thanks for anymore ideas.
Ryan
Old Feb 10, 2002 | 03:32 AM
brett_d's Avatar
brett_d
grinding sound
You can check the rear U-Joints they can also be the culprit!
Old Feb 10, 2002 | 08:23 PM
Ryan50hrl's Avatar
Ryan50hrl
grinding sound
Rear ujoints just were replaced.
Ryan
Old Feb 10, 2002 | 10:10 PM
slave2dafords's Avatar
slave2dafords
grinding sound
well here is another idea it might be in the trans itself now that it is coming while in 2wd the extra pull of 4x4 could have started your awareness and as the problem has gotten worse as it always does it has gotten to the point that 2wd is enough drag on it. just trowing ideas out.
Old Feb 10, 2002 | 11:57 PM
Skottt's Avatar
Skottt
grinding sound
Does it do it in 2 Hi with the hubs unlocked, or only when they are locked?
Scott
1995 F150 4X4
5.0 Reg Cab SB
33" BFG MT
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=479&.jpg
Old Feb 11, 2002 | 03:07 AM
madman666's Avatar
madman666
grinding sound
